A/c PROBLEM think it maybe a compressor
  • Thread starter Thread starter Huff890
  • Start date Start date Feb 19, 2020
First Prev 2 of 2
H
Huff890
35
Jacksonville
Mar 15, 2020
#21
  • Mar 15, 2020
  • #21
jrichker said:
The A/C clutch is about $100 new or you can buy a compressor from the junkyard with a working clutch for about $50. The puller is about $21 if you have to buy one, AutoZone may rent you one for free.
The clutch hub is usually what fails, the rubber shock damper shears off from the steel hub and plate. The pulley turns, but the hub doesn't when you power up the A/C.
www.rockauto.com Ford MOTORCRAFT Part # YB289A $39.00
The hub comes off without much problem if you have the puller. You don’t have to do anything with the refrigerant (R12 or R134a), you can replace the clutch without draining and refilling the system. The snap ring hiding inside the hub is the only tricky part.
Remove the nut; remove the snap ring (if present) and then remove the washer. Loosen the puller tool center bolt so that you can get the larger threaded section of the puller screwed into the clutch hub. Tighten up the center bolt on the puller and the clutch hub will come off.
Clutch hub puller tool
Part Number: 27002
Alternate Part Number: 59509
AutoZone and most other major auto parts chain stores will rent or loan the puller. Cost is $21.00 if they don’t have one to loan.
A few simple electrical tests are advised before popping out the wallet to buy a clutch assembly. With the engine running, use a test light connected to the 2 wires on the A/C clutch harness to make sure you have voltage when you turn the A/C on. If the system is low on refrigerant, the clutch will not engage (safety feature, keeps you from burning up the compressor due to no oil). There is an aluminum canister on the firewall with a large hose leading to the A/C compressor. There is a pressure switch on it with a 2 wire connector: pull the connector off and jumper the wires. The compressor circuit will power up, and the test light will light if the electrical circuit is good. This test is also a good way to check the compressor & clutch if the system is low on refrigerant. You can jumper the wires and the compressor will turn if the clutch is good.
The clutch also has a relay that shuts off when you go to WOT (wide open throttle). It is located on the passenger side inner fender well. The close proximity of the relay to the headers can cause the insulation on the wiring and the relay socket to deteriorate. The relay can become non functional when this happens.
Caution: replacing the A/C compressor seal requires removing the R12 refrigerant. By law you are supposed to recover it and not dump it to open air. I will leave that up to you...
The A/C compressor seal is less than $12. See AutoZone Santech A/C Compressor Shaft Seal Kit MT2039. You will need a pair of internal snap ring pliers to remove and install the seal snap ring
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
[/img]
I jumped the connector on a.c switch next to the firewall used a test light on the connector side of the ac compressor and i have no power on both sides
H
Huff890
35
Jacksonville
Mar 15, 2020
#22
  • Mar 15, 2020
  • #22
is there any chance my ignition module would affect this i have a zip tie temp fix but it affected my blower motor lights alot of things didnt work
H
Huff890
35
Jacksonville
Mar 15, 2020
#23
  • Mar 15, 2020
  • #23
so i tested everything with a test light i had power and ground up from the a/c switch by the firewall to the diode so i upluged the diode and gave it power and ground from the batt. clutch still woundnt engage so i think i need to replace the diode on the clutch?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 16, 2020
#24
  • Mar 16, 2020
  • #24
The diode will not affect your problem; it just clamps the reverse voltage spike that happens when the clutch coil power is turned off.
Using a diode as a dampener in automotive circuits:
Theory of operation:
The diode acts as a surge absorber or one way gate. Anytime you turn the power off an inductive load (coil, motor, solenoid, etc) the collapse of the magnetic field creates a voltage spike of opposite polarity to the voltage applied. The positive wire sees a negative spike and the negative wire sees a positive spike. The diode is wired backwards so that it does not conduct during normal forward operation. When the magnetic field collapses, the diode sees the reverse polarity spike and clamps it. This prevents the spike from possibly damaging the rest of the electronics in the car.
When used to clamp spikes in automotive circuits, connect the lead that comes from the end of the diode that has the band on it to the positive side of the circuit. Connect it the other way and you will make smoke.
Diode markings
A properly functioning diode will measure very high resistance or open circuit in one direction. Reverse the meter leads and it will measure a lower resistance.
Reactions: General karthief
H
Huff890
35
Jacksonville
Mar 16, 2020
#25
  • Mar 16, 2020
  • #25
Diode markings
Yea but shouldn't I be getting power after that connector I have power all the way up to the a.c compressor harness
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 17, 2020
#26
  • Mar 17, 2020
  • #26
Do you know how to use your meter to measure resistance?
H
Huff890
35
Jacksonville
Mar 18, 2020
#27
  • Mar 18, 2020
  • #27
Yes
H
Huff890
35
Jacksonville
Mar 18, 2020
#28
  • Mar 18, 2020
  • #28
I'm getting O.L. on the power side
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 18, 2020
#29
  • Mar 18, 2020
  • #29
From your answer, I'll take it that you don't know how to use a meter to measure resistance.
Never measure resistance with the circuit power on. You will get inaccurate readings and may damage the meter.
Here's some help... https://www.wikihow.com/Measure-Resistance
If that didn't help, here are some more resources...
Google Search
www.google.com
Digest that and we'll start testing the components of the A/C clutch power circuit...
KRUISR
1,880
1,024
143
Mar 18, 2020
#30
  • Mar 18, 2020
  • #30
Fastest way to see if a/c clutch works is unplug the 2 wire connector on the compressor. This is power and ground to the clutch coil. Run jumpers from battery to the 2 wires with engine running. If clutch is working, pulley will start spinning when jumped. If clutch is working and A/C doesn't run normally, issue is elsewhere in wiring.
In my opinion (and was the reason in my case) the next possible cause would be the A/C clutch relay (looks same as fuel pump relay and is interchangeable). This can be jumped to test as well. On my 90 it is located passenger side near factory air box inlet. With engine running, jump the 2 heavier gauge wires at the relay. System will start if issue is a signal problem to relay or bad relay. If jumping works, can test relay resistance to see if it is good or simply replace relay.
I know this is not the troubleshooting guide and definitely not as thorough. It will give a ruling on clutch functionality in a couple minutes. It is not the fix, but can rule out clutch as the issue very quickly.
H
Huff890
35
Jacksonville
Mar 20, 2020
#31
  • Mar 20, 2020
  • #31
Google Search
www.google.com
I didnt have power to it I disconnected the a.c harness from the compressor and the connector on the side of the engine bay so yea I do know how to
H
Huff890
35
Jacksonville
Mar 20, 2020
#32
  • Mar 20, 2020
  • #32
I jumped from my battery to the compressor and the clutch didnt do anything
R
RonaldCarter
USA
Apr 23, 2020
#33
  • Apr 23, 2020
  • #33
It is the faulty compressor or there is some other issue with the ac unit. As such issues can get fixed by own, contacting experts is the only solution to such problems.
First Prev 2 of 2
G
2005 Mustang GT AC cycling on and off every minute
  • GeorgeSwadling
  • Jul 12, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 12, 2025
GeorgeSwadling
G
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
J
2003, 3.8l with air conditioning problems
  • Jimb0z '03
  • Nov 3, 2024
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2024
Jimb0z '03
J
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • dan50
  • Jul 18, 2026
dan50
