  • SN95 4.6L Mustang Tech
A/C underdrive issues
  • Thread starter Thread starter jmd2000gt
  • Start date Start date Feb 27, 2004
J
jmd2000gt
Lancaster, CA
Feb 27, 2004
  • Feb 27, 2004
Hey Im new to this joint. Got an engine question. My 2000 GT is fairly stock with Steeda pulleys and not much else on the motor. Heres the problem: last summer I drove the car to Vegas in the heat. The A/C worked fine on the way there, but on the way back I noticed the A/C air steadily getting warmer. After about 2-3 hours on the road, in about 100 degrees heat, the air was hot so I shut it off, thinking I sprung a leak. The next day I drove the car to work and the A/C blew cold, no problems. Of course the dealer couldnt find anything. Anyone ever had this kind of problem with underdrive pulleys? Is it possible that with the compressor turning slower it couldnt keep up with the necessary heat transfer? I havent gone on any road trips since, so I havent ran the A/C for much longer than an hour. Thanks in advance.
Joe
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Feb 27, 2004
  • Feb 27, 2004
i never had a problem with mine. the only issue was that i needed to turn the dial one knotch more to get the same cooling effect as before the pulleys.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Feb 27, 2004
  • Feb 27, 2004
This will happen if the compressor clutch is going out. Was it making any noise? If it is still under warrenty tell them it is not cooling the way it used to. I did that on my 1999 Dakota and they just changed out the compressor...no questions.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
M
  • mnky99
  • Sep 5, 2025
mnky99
M
