A/C Vacum line question
89GTBLKonBLK
24
I have been having trouble getting cold air out of my middle vents. it only will come out of the floor and defrost on max ac. I found the yellow vacum line behind the dash not hooked to anything, Does anyone know where this line goes, it has to be close by because its not very long. It says in the wiring diagram it is suppose to go to the defrost door or something which would make sense. please help, it is to damn hot in New Mexico to not have a good A/C:mad: . Thanks
One end is connected to the backside of the control, the other end is connected to the vacuum motor. The motor is located behind the the control, it's a gold colored can a little shorter than a soup can and is mounted lengthwise front to back. The yellow line connects to the end closest to the firewall.
Is it directly behind the switch? is it possible that it could be missing, I found the one that is right of the panel switch with is the recirculation one but i cant seem to find the other, I will keep looking.
Will probably be a tight squeeze, but it may not be too bad if you moved the horn relay/chime assembly out of the way (2 screws). You can easily see the motor looking up and to the back of the controls from the gas pedal perspective.
