A/C Valve leak
My compressor was kicking on and off more often than it should so I got a can of R134a and it took about 6oz and the low side pressure was riding where it should. Next morning when I hit the defrost i didnt feel the compressor kick on. Popped the hood and there is green dye all over the place under the low side valve. I can't get it to seal. I tried rotating the pin but it just keeps bubbling.
Can you replace just the valve core or does the whole thing thread off like the old ones? Any ideas?
The core is serviceable. Service just like a tire only bigger. Suggest that you do both high and low at the same time. Also, replace the covering cap. There is an O-ring in the cap that help protect against slow leaks.
