  • 1994 - 1995 Specific Tech
A/C Wiring
  • Thread starter Thread starter 95Beast
  • Start date Start date Jul 30, 2009
9
95Beast
Charlotte, NC
Jul 30, 2009
  • Jul 30, 2009
Im new to these forums but I did do some searching but came up short so if I missed something sorry. My AC has stopped working and it is due to a electical problem. There is no power coming from the fuse box to the compressor which I have not really dug into yet but I do know it is not the fuse. So I was just curious if anyone had a AC wiring harness they would sell or a diagram of the wiring for it. 1995 5.0 Cobra
HISSIN50
34
129
Jul 30, 2009
  • Jul 30, 2009
Power goes through the fusebox, to the HVAC controls, to the LPCS, the WOT relay and the clutch. I would start tracing the circuit till you find where power is missing. If you're low on refrigerant, power will go into the LPCS but won't leave it.
9
95Beast
Charlotte, NC
Jul 30, 2009
  • Jul 30, 2009
yeah the first thing I did when I went out is check and try to fill the refrigerant. Do the explorers or old crown vics have the same wire connector to the ac compressor as the 5.0's do?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 31, 2009
  • Jul 31, 2009
If you've verified your charge is sufficient, pull the plug off of the low pressure sensor on the accumulator and put some sort of jumper between the wires on the harness. If your AC turns on, but didn't prior to that, the LPCS needs replaced.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
