  • 1994 - 1995 Specific Tech
A couple questions about shift lights
  • Thread starter Thread starter BlueOvalStangGT
  • Start date Start date Aug 22, 2004
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Aug 22, 2004
  • Aug 22, 2004
Since my tach is way off now ( http://forums.stangnet.com/showthread.php?t=494910 ), I was thinking about ways to get an accurate reading for shifting. I dont want a gigantic tach that mount on my dash cause I dont realy like the way it looks but I was wondering avout shift lights. Can you make them come one at different RPMS for different gears? IE: 5800 in firstm 5600 in second...... How do you adjust them and whats a good kind? I want a small one that I can fit behind my AC vent. I noticed my MSD 6btm has a plug fir a tach or a shift light, I forgot. Can I use that for soemthing?
baglock1
The Bartender
6,612
Space Coast, FL
Aug 22, 2004
  • Aug 22, 2004
You can run a shift light off of the 6BTM by tieing in to the ignition wiring. But it usues an RPM pill setup and so you can't get different RPMs with each gear. To the best of my knowledge, the "lowest" MSD module that does that is the 7 series programmable (but I may be mistaken).
BlueOvalStangGT
2,849
Aug 22, 2004
  • Aug 22, 2004
Im not sure what you mean, is there a shift lights that light up at different rpms or no? I was looking at the MSD part # 121-7552, hows that?
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Aug 22, 2004
  • Aug 22, 2004
From what I know, a shiftlight will only light up at whatever rpm you programmed it. Most of the lights use pills which suck. Mine is adjustable at every 100 rpm. Its the Raptor shiftlight. Do a search on here and you'll see a few people that use it and love it.
So whatever gear you are in, it will always light up at the same rpm.
9
94DreamGT
593
Indiana
Aug 22, 2004
  • Aug 22, 2004
http://www.harlan-engineering.com/store/store.html
Cheap...small...single-unit...easy to program...color variety option...works good!
R
Engine Ignition issue test light question
  • Rick1992
  • May 29, 2025
Fox 5.0 Mustang Tech May 30, 2025
Rick1992
R
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
P
Electrical MSD box wiring for an 88 GT- few questions.
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 25, 2024
pindude80
P
C
1965 Mustang Lower Control Arm Question.
  • chopper1876
  • Nov 9, 2024
1965 - 1973 Classic Mustangs -General/Talk- Dec 7, 2024
GOvert
G
