Fox A Couple Questions
James V
5 Year Member
Feb 26, 2017
409
144
63
Connecticut
Instead of making 2 different threads I will just post my questions in this one.
1. Where can I find a bumper cover like this?
2. I found an ad for someone selling the arms, spindles, rotors, calipers, and rear end off of a 1995 mustang, would that be a direct fit, what else would I need?
Still working on my 93 notch, learning as I go. Thanks!
That's a mach 1 lower valance. Its almost a direct fit to a fox with minimal alteration. This is from LMR
You'd need 5 lug wheels, the sn95 rear is wider by about 3/4 inch per side , you'll need a 1993 cobra booster, sn95 master cylinder ( I used one for a 98 v6 ), a sn95 brake proportioning valve....or gut yours and use an adjustable proportioning valve.
You'll also need to change the e brake extension cable...or retrofit an sn95 e brake handle and cable bracket into your fox ( like I did ).
I think that lower valence is custom. It looks like s Mach 1 lip, but the bumper seems different from standard LX. Almost looks like it's all molded together.
Hard to see in the pic as it's dark
