  • 1994 - 1995 Specific Tech
A few problems, need some help.
  • Thread starter Thread starter 95_5.0_stang
  • Start date Start date Oct 18, 2005
9
95_5.0_stang
172
Lansing, MI.
Oct 18, 2005
  • Oct 18, 2005
Well, I can't seem to figure out what the problem is here. I swapped a 88' motor/trans(5 speed), etc... into my 95' that used to be a v6/auto. Well, I got it running and driving suprisingly very well right now. Sorscode wired it up for me. But there are still a few problems. It's running very rich, people say I have small black clouds when I step on it. And it smells extremely gassy. Another thing is a little bit of hanging idle. When pushing on the clutch, it want's to stick around 2k or so....this problem may not be there anymore though, because I just cleaned TB (a little bit, didn't clean it real well) and it doesn't seem to hang quite as bad. So we'll see as time goes by. And the last problem is it doesn't like to idle when it's cold. Since I replaced the IAC it start's/idles alot better though. But it still needs to be warmed up when starting it when it's cold, otherwise it won't idle. Now, I already pulled codes awhile back, and replaced coolant temp sensor, and then I replaced IAC, then deleted codes and check engine light hasn't came back so far. But I still have these problems. Any ideas guys?!
9
95_5.0_stang
172
Lansing, MI.
Oct 18, 2005
  • Oct 18, 2005
Any ideas?
9
95_5.0_stang
172
Lansing, MI.
Oct 18, 2005
  • Oct 18, 2005
95_5.0_stang said:
Any ideas?
TrueBlue95GT
966
Connecticut
Oct 18, 2005
  • Oct 18, 2005
How many miles were on the 88 motor before you put it in? You could try changing the MAF, IAT, and O2 sensors. Or maybe you just need a new fuel pressure regulator.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 18, 2005
  • Oct 18, 2005
Well he said when he steps on the pedal, which I assume he means WOT. So I would start w/ your maf/iat/ect first.
Scott
9
95_5.0_stang
172
Lansing, MI.
Oct 19, 2005
  • Oct 19, 2005
The IAC and o2 sensors are brand new. And I cleaned the MAF. Could it possibly be the fuel pressure regulator? What are some symptoms of those failing.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
