A lil help please? :)
Jester84
Hey guys!
I finally got our car running last night after replacing the parts that were stolen off of it last month. I do have a question though.
Look at this pic.. its right above cyl. #2...wtf is the hole for and should it be there..if so.. should it be open or sealed?
Thanks!
what parts did you replace? Something is not right with the intake mounting to the head. something was milled down looks like that is why intake is not fitting on the head the way it should be. That hole should not be there the intake should cover it
Well. the lower intake was there already, they stole the upper GT40 intake and all attached to it. So I just replaced that stuff. I guess I will take it off and have a look at it ...but there prolly wont be much I can do So I might just seal it up on both sides.
The transmission is my concern now. :(
gotcha, well if it worked before, should work again right?
I feel ya on transmission woes. I desperately need a new transmission. I've rebuilt the one in the crapi 4 times in 5 months because I havn't been able to afford new parts so I'm making half-broke stuff work. Now if I put it into 4th it will not come out again, you only get 2nd if you pull back really really really hard. Tailshaft bushing is shot, rear seal is shot so now she drinks a quart of gear lube a week (gear lube leaks slower :D )
