  • 2.3L (N/A & Turbo) Tech
A question about 2.3T engine
  • Thread starter Thread starter jstang209
  • Start date Start date Aug 12, 2004
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 12, 2004
  • Aug 12, 2004
I found an 84svo 2.3T engine with only 62k miles on it(car was wrecked) for 250 dollars. Im thinking about buying it because that swap seems alot more easier than the 5.0 swap i was planning to do. Anyways did the 84 have the larger garret turbo or the smaller ihi turbo? and is there any other EASY ways to add hp other than exhasut, intercooler, and cai? Thanks
Sims6986
50
Indy
Aug 12, 2004
  • Aug 12, 2004
get (or make) a boost controller.
realtripp
202
Ft. Madison, IA
Aug 12, 2004
  • Aug 12, 2004
I think all SVO engines had the garret turbos
N
NY Eric
67
Carmel NY
Aug 12, 2004
  • Aug 12, 2004
Garret unless ford swaped it out when it went. but with 67k I would bet it is original.
Bearded Forever
Type O Danzigative the Dark
4,927
Vinland
Aug 12, 2004
  • Aug 12, 2004
The only car that has the ihi turbo is the 87-88 Thunderbirds.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 12, 2004
  • Aug 12, 2004
oh ok.. anywayz is a boost control the only thing you guys can think of? does anyone know how much hp the the stock 84 svo had? and if i have any chance of beating a stock auto 5.0
slow88stang
144
St Albert AB
Aug 12, 2004
  • Aug 12, 2004
The 84 svo had 175 hp and theres lots of mods you could do to pick it up. Just search around in the 2.3 section, maybe take a look in the tech section sticky, theres lots of things in there. It would probably be a good battle with a stock auto 5.0 if you were 5spd but with a few minor mods it would blow it away.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 13, 2004
  • Aug 13, 2004
can i use a computer from 87 tc with this engine or do i need an svo computer
N
NY Eric
67
Carmel NY
Aug 13, 2004
  • Aug 13, 2004
yes you can use the tbird cpu. you should chek out gt350's site it has a walk through of the whole procedure. it is no big deal. it is easire with a svo cpu. The 84 cpus are easy to come by though. I think I have one or 2 laying arround the hard part is the wiring harness. most 84 harensses are shot. so you have to pick the lesser of the 2 evils.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 13, 2004
#10
  • Aug 13, 2004
  • #10
stinger said i dont need a wiring harness for the swap just a couple of inches of the vam harness
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
A
Engine Turbo 5.0 Mustang bad misfire at WOT
  • AwxyMoron
  • Apr 3, 2021
  • 2 3
10K
Fox 5.0 Mustang Tech May 5, 2021
a91what
