I rebuilt my A4LD transmission (1989 2.3 vert) following the directions in the Explorer forums rebuild DIY. Everything, except the 2nd gear band, looked great so I just replaced the 2nd and 4th gear bands and the shift puck things. Before the rebuild, I had no second gear but everything else worked fine. Now I have only 2nd gear. Or, more precisely:
Park works fine,
Move the shifter to R, I get neutral.
Move the shifter to N, I still have neutral.
Move the shifter to OD, I get reverse. If I go back to N or R, I still have reverse.
Move the shifter to D, I get neutral.
Move the shifter to 2, I get 1st gear.
Move the shifter to 1, I still get 1st gear.
Move the shifter to 2, I still get 1st gear.
Move the shifter to D, I still have 1st gear.
Move the shifter to OD, I still have 1st.
Move the shifter to N, I get neutral.
Move the shifter to R and I have reverse.
Move the shifter to Park and I have park.
It sounds like a valve body problem to me. I didn't really take the valve body apart other than to replace the gasket. I believe the check balls went in the right place.
Any ideas what I might have done wrong? How do I start to troubleshoot this? This is my first auto trans rebuild and it didn't seem that tough, just really messy, until I got to this problem.
Thanks in advance,
Bob Martin
Park works fine,
Thanks in advance,
Bob Martin
