??? about brakes on a 2001 V6
V6's use the same K-member as the 5.0, but not the 4.6L
In other words, if you want to convert a 3.8L to a 4.6 you'll need a new K-member, but if you wanted to convert it to a 5.0, you just need the new engine mounts.
The 3.8L and 5.0L share a lot of similar dimensions and mounting setups.
This is not true, I am doing a GT swap, I do not have to change my K member.
A buddy of mine is doing a 5.4 swap into his Six and when he blew the motor and the engine was out we dropped in the 5.4 block and guess what, it matched perfectly. He is using a Navigator block also.
The 99+ 3.8 swap with a 4.6 is a basic drop in. Why would Ford make two seperate parts for? That does not make sense.
THEY ARE THE SAME.
T
