- Jun 30, 2007
- 71
- 0
- 0
I have successfully removed the tank, broke the ends of the
clips on the high pressure fuel lines, and removed the old
fuel pump.
I installed the new pump and reconnected the power clips.
I noticed that I had a little gas seepage before dropping the
tank and assume the filler tube rubber seal may not be up
to snuff (89 GT).
Do you think a little RTV will be needed or a new Gromet?
Do you see any problem with replacing the fuel line clips?
Any other way to see where a seepage leak may be coming from?
Any tricks to use for the reinstall?(I have the car on a Bend Pac lift)
Thanks George
