ABS Light and C-Clip Eliminators
damacman said:
As long as you pull the ABS rings off of the stock axles and put them on the strange axles, you'll be fine. I know because I just got done doing this.
you cant use the abs rings with c clip elims
and yes the abs light will be on and the only thing that can be done is pull the buld I pulled the fuse and will be pulling the buld tomorrow
cause I went with a the 33spline moser spool and axle setup with moser c clip elims
