  • SN95 4.6L Mustang Tech
ABS light problem - had code read -still no resolution
  • Thread starter Thread starter spederman
  • Start date Start date Aug 23, 2008
First Prev 2 of 2
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 26, 2008
#21
  • Sep 26, 2008
  • #21
The tires has got to be the problem if they are reading 3-4 MPH faster. You should stick a 275 up front to get them close to the 305 rears. DO NOT PULL the bulb! That is silly and obviously won't fix anything. If you have to slam on your brakes the ABS isn't there, the wheels could lock up and then you wreck the car again, don't do that!
spederman
732
#22
  • Sep 26, 2008
  • #22
I got it all taken care off now. I did the tire calculator and the 255/40/18 was the perfect size to put me within 1% of the size of the rear tires. Plus now it looks a hell of a lot better too, since the side wall matches the size in the rear. And what else is surprising that i didnt think of is the ride is so much better having a larger side wall ratio in front. Its not as harsh of a ride over bumps and i dont bottom out/scrape as easy.
W
Will Smith
191
Cape Coral, FL
Sep 26, 2008
#23
  • Sep 26, 2008
  • #23
Mustang5L5 said:
Um...no it doesn't
Hate to break it to you, but what you just described sounds like a problem with your ABS system. That's NOT how it should work at all. You might want to try to fix that.
This is not a Mustang thing. That applies to ALL vehicles. The ABS light comes on during startup to tell you if the bulb is functional and then shuts off until a code is stored in the system. When a code is stored, the ABS light comes on and the system is disabled. During ABS use, the light DOES NOT come on at all. You will never see the YELLOW ABS light at all UNLESS something is wrong.
The traction control system (which is part of the ABS system BTW) does display a spinning wheel when the system detects wheel-spin and activates. That's also not a Mustang thing...all cars equipped with TCS do it to tell you if the system activates.
If you are braking hard, activating the ABS and the light comes on, that means your system is finding a fault somewhere during use and deactivating itself. Also, the car shouldn't feel violent during ABS use. Other than the brake pedal vibrating, the car should track and drive fine with no vibration in the car itself.
I'm not trying to be a jerk here...but your ideas about how ABS systems work is incorrect
PS. If the red BRAKE light comes on during hard braking, it means you are low on brake fluid
Exactly...
Mcstango2001
11
#24
  • Dec 24, 2009
  • #24
Hey guys
so my abs light has been on for quite some time
i cleaned out the front abs sensors, nothing.
how do i get access to the back sensors?
First Prev 2 of 2
A
GT ABS Module in a 2001 Cobra
  • Aamer309
  • Oct 17, 2026
  • SVT Tech Forum
SVT Tech Forum Oct 18, 2026
Aamer309
A
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Tuesday at 11:55 PM
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Tuesday at 11:55 PM
dmw_4814
D
O
ABS light on. Can't get codes
  • oldtimeracer
  • Jul 12, 2024
4K
SN95 4.6L Mustang Tech Aug 28, 2024
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
