ABS light reset?
nctrader77
27
I got an ABS light at about 80K. I can't see anything wrong. I did clean the front sensors, and the fluid was a little low. However, after doing these two things it still would not reset, even with the battery power removed for over night. Can anybody give me directions on how to reset the code? I really don't want to take it to a dealer.
Thanks
IF it doesnt go out there is still something wrong, one of the wheel sensors could be bad, or several other things, your brakes will work normal, and unless you drive in the winter or bad weather conditions you will probably never know the diffrence. You could always take it somewhere to have them find the problem and then replace the part yourself if you cant locate it.
