  • SN95 4.6L Mustang Tech
ABS Light?
  • Thread starter Thread starter sleepergt00
  • Start date Start date Nov 6, 2005
sleepergt00
  • Nov 6, 2005
My ABS dummy light comes on and off at times. Doesn't seem to be any correlation to when I apply the brakes. Anyone else have this happen. I do have the Cobra brake upgrade, however this was occurring before that upgrade.
ToplessStang
591
Montreal, Canada
Nov 6, 2005
  • Nov 6, 2005
You have to get it scanned to find out what code is in the module. Most likely an ABS wheek sensor.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 6, 2005
  • Nov 6, 2005
I beleive there is a way to ground the ABS test port and get the ABS light to blink the codes to you. I am unsure how though or what the codes would mean.
Most likely it's a ABS wheel sensor on it's way out. You might want to give them a quick glance and see if anything looks corroded or cracked.
sleepergt00
  • Nov 6, 2005
I forget to mention that the sensors looked fine, not sure if that actually are, but they've been physically checked.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 6, 2005
  • Nov 6, 2005
Did youunplug them and check the resistance with a meter?
You should get some resistance with a meter. If the sensor is open it is faulty. Wiggle the wiring around to see if it's an intermittent open
sleepergt00
  • Nov 6, 2005
Will do. Thanks
A
GT ABS Module in a 2001 Cobra
  • Aamer309
  • Oct 17, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 3, 2026
Mustang5L5
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
