  • 1994 - 1995 Specific Tech
ABS light
  • Thread starter Thread starter yellowstang1994
  • Start date Start date Nov 17, 2007
yellowstang1994
338
  • Nov 17, 2007
Hey guys,
I've had this ABS light on for a while now. It comes on after 5 or 10 minutes of driving. Whatever the way was to get the codes off where you jump the two wires together, I tried that but nothing happens because there probably isn't a code in there until I drive. How do I find out what it is? Drive the car until it comes on, pull over, then try it? I dunno, anybody else have this problem?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 17, 2007
  • Nov 17, 2007
I've never had any ABS issues personally, so I can't help in the troubleshooting, but I do have this site saved in my favorites for instances such as these:
http://www.veryuseful.com/mustang/tech/brakes/absDiagInfo.html
parchisi
519
New Mexico
Nov 17, 2007
  • Nov 17, 2007
my abs light too has been acting up. One time I decided to hit the brakes hard, and the front wheels locked up on me. As soon as I can, i'm going to get that checked out.
mustang6tee8
375
College Station, TX
Nov 18, 2007
  • Nov 18, 2007
my abs light has been on for about a year.... hehe
Pops Fun
961
14
59
Cincinnati, Ohio
Nov 18, 2007
  • Nov 18, 2007
Hi
Mine comes on when I have a different ratio rear tire on back.
Steve
yellowstang1994
338
  • Nov 19, 2007
hmmm. I do have a slightly larger sidewall tire on the back, that is probably the case because this hadn't started until I put my wheels on. I guess I will eventually have to get the right size tires. It just sucks because I heard that if your ABS light is on, no matter what the problem your ABS isn't functional anymore right? Not very good with the bad weather coming up.
Pops Fun
961
14
59
Cincinnati, Ohio
Nov 20, 2007
  • Nov 20, 2007
Hi
Well slightly won't cause it it has to be quite a bit... I run about an inch difference and don't get the light but when I put my M/T dr's on I have about a 3 inch difference then I get the light in particular when I reach a certain speed, around 45 or so. it is the ratio of the tires.... search abs it's been written about a few times.
Steve
D
DarkStallion095
93
Rancho Santa Margarita, CA
Nov 21, 2007
  • Nov 21, 2007
you're just going to have to catch it!
Keep a paper clip with you in a U-shape ready to jam in there (Anti-Lock Test connector). when it comes on pull over in a safe place, turn off the car pop-the hood, jump the connector, get into your car with a paper and pencil ready. turn the key to power accessories (do not turn the car on). Abs should come on and count the light bleeps. Blink, Blink, Blink, (Pause), Blink, Blink, Blink, Blink then the abs will stay on. 3 blinks and then 4 blinks corresponds to a Code 34 for example. Your going to have to catch it when its on to get a code. Once you have a code your set. Then someone here can help or better yet look up my thread on my ABS. I forgot who helped me but I am sure they will do the same for you. Good Luck. Its more than likely just one of the sensors. 50 bucks and pretty damn easy to install, especially the rear. Oh and when your abs light is on, you will not have any ABS whatsoever. Very bad news under wet or emergency situations. Trust me. The first thing that you're going to want to do in an emergency situation is slam on your brakes and without the discipline or experience you can really mess yourself up. Try to get the abs working man.
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
