  • SN95 4.6L Mustang Tech
ABS light
  • Thread starter Thread starter spederman
  • Start date Start date Mar 8, 2008
spederman
732
  • Mar 8, 2008
My ABS light keeps coming on intermittently. It does it half the time after i drive it. About 10-15 min worth of driving and if i get on it hard, the light clicks on. If i shut the car off, and turn it back on, its gone. Its never there right from start up.
It started doing this after i took my car mud boggin through a ditch at 80mph (not on purpose,not making a habit of this ). I assume its prolly some mud that got into the ABS sensors since all the wheels were caked with mud.
Where on the brakes are the ABS sensors? Does each wheel have one? How do i clean them out or test the sensor to see if its working? Also, I heard that you need a special code reader to read the ABS codes, will the XCAL 2 read ABS codes?
R
ron97
  • Mar 9, 2008
I had the ABS light also, have a 97 GT, on my car there is a red box next to the power supply box in the engine compartment on the left side, its got anti lock test on the top. There is a way to wire a jumper on two of the contacts in the box, then when you turn your ignition on, the ABS light will flash giving you a code that tells you what's broke. Mine flashed 3 and then 2, 32 means the right rear sensor is bad. The internet has the codes, and jumper contacts.
BCB00GT
420
Mar 10, 2008
  • Mar 10, 2008
Take the wheel off the car. Look down behind the rotor and you will see a small metal "stem" just over the wheel hub (which has teeth). The metal "stem" is the pickup sensor to make sure the hub is turning. There is a E8 star screw that holds the sensor to the spindle. Either use the E8 socket and remove to clean (preferred) or just spray brake cleaner using the straw attachment.
Also, each wheel has one sensor. Clean all and the drive the car to see if you still have the light. Basically if your hub has lot of crap such that the sensor can not pickup the "teeth", then the sensor thinks the hub isn't moving. You may need to clean the "teeth" area of the hub for the one you went boggin in.
BobHyatt
378
  • Mar 10, 2008
another way to get the ABS light to intermittently go on...
run different sized tires/wheels on different corners of the car. The ABS computer does not like to see a steady-state where some sensors are reporting higher wheel RPM than others. It assumes something is amiss. Using the donut spare can cause this, it has on ours...
9
97speedster
134
stanwood,wa
Mar 11, 2008
  • Mar 11, 2008
Mine did this for awhile and I traced to different sized tires from front to rear just enough of a difference to intermitantly cause the abs light to come on. I had only 1 1/4" difference from front to back.
spederman
732
  • Mar 11, 2008
Thanks guys. I'm sure it has to prolly do with dirty abs sensors, instead of the tire size. I've never run the correct size tires on this car since i bought it new and its never given me the abs light. Its only started since after i got in this wreck.
the98stang
2,408
Clovis, CA
Mar 12, 2008
  • Mar 12, 2008
As soon as I put Hawk pads on my stang the ABS light came on. Those brakes create so much brake dust it's ridiculous. You can take some Q-tips and clean the sensors on each wheel...that might fix the problem. If it's not the sensors it's the actual ABS unit itself. The dealership is the only place that can tell you which sensor(s) is bad or if it's the ABS unit. A special ABS code reader is required.
rabidscoobie
616
12
48
College Station,TX
Mar 14, 2008
  • Mar 14, 2008
A couple years back I had that same problem,have no idea why.But I took off the battery cables for about 15 mins and then reconnected and havnt seen the light since.That light just came on for no reason,I didnt pull your stunt nor did I work on anything at all...it just came on.btw I have an 01 GT.
A
GT ABS Module in a 2001 Cobra
  • Aamer309
  • Oct 17, 2026
  • SVT Tech Forum
SVT Tech Forum Tuesday at 10:25 AM
Mustang5L5
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
O
ABS light on. Can't get codes
  • oldtimeracer
  • Jul 12, 2024
4K
SN95 4.6L Mustang Tech Aug 28, 2024
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
