  • SN95 4.6L Mustang Tech
ABS sensor
  • Thread starter Thread starter rolenna00gt
  • Start date Start date Apr 29, 2004
R
rolenna00gt
196
k-town tn
Apr 29, 2004
  • Apr 29, 2004
How do you know if it is bad or not. My ABS light is on which turns my trac control off automaticaly. I think it is a wheel sensor but how can I tell if it is bad. I thought if the wire was cut or somthing like that but what if the wire is not cut, do you check for volts or something like that??
XTONKAX
619
UT
Apr 29, 2004
  • Apr 29, 2004
The only way to know for sure is to get the code pulled. It will not show on a normal code reader. I paid about $80 and they found that my driver's side rear speed sensor was dead. I'm unsure if there's anything you can do by yourself to test it.
R
rolenna00gt
196
k-town tn
Apr 29, 2004
  • Apr 29, 2004
How do you test is your self, hat is the whole question I m not sure how to test it my self I can get the front senors for 31.50 and the rear for 50.60 each that is..Ford loves to screw their faithful dont they
XTONKAX
619
UT
Apr 29, 2004
  • Apr 29, 2004
I'm sure it's a continuity thing, but don't know the specs. The pricing on the sensors sounds right. It's the labor that will kill you at the dealer. I went to the yellow pages for a local place specializing in ABS systems. They also ended up having to put some dielectric grease on the ends of the wires where it plugs into the ECU. Haven't had a problem with it since. This made me wonder about the rear sensor, whether it was truly bad, but they claim it was. All told, it was about a $300 adventure.
Good luck, and keep us posted.
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
