  • SN95 4.6L Mustang Tech
ABS sensor
  • Thread starter Thread starter WashburnGT
  • Start date Start date May 12, 2006
WashburnGT
32
I-70
May 12, 2006
  • May 12, 2006
So my ABS and "trac off" lights came on the other day when I started up my stang...haven't turned off since. So I had a guy at work hook it up to an OBDII tester and it threw out a code saying my rear driver-side sensor wasn't functioning properly. We went through all the trouble shooting guides for it until the point where it said I should just replace the sensor and/or ring. My question is has anybody had to do this? Should I try it myself or just take it to a Ford dealership? Any advice or guidance would be helpful.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 12, 2006
  • May 12, 2006
it's not hard to do.. it's one bolt holding it in, a inverted torx I can not remember the size. But it might have been E8
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
May 12, 2006
  • May 12, 2006
yeah you where right its a E8 female torx
WashburnGT
32
I-70
May 13, 2006
  • May 13, 2006
great...thanks for the info guys
smueller
57
Wisconsin
May 13, 2006
  • May 13, 2006
It's not hard to do. Just make sure you use some good penetrating oil or WD 40 to loosen up the sensor, mine were in there pretty good.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,118
224
Massachusetts
May 14, 2006
  • May 14, 2006
Unplus the sensor and put a DVM on it and check resistance. Most likely it will be open as the ABS sensors are prone to cracking, getting water inside and shorting out internally.
It's an easy fix as well
TangerineGT96
134
arkansas
May 15, 2006
  • May 15, 2006
anyone know how much a abs sensor is?
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
May 15, 2006
  • May 15, 2006
Not sure, but try PMing Randy S for a great price.
macdstr8up
40
Greenville, ohio
May 15, 2006
  • May 15, 2006
Mine were like 50 bucks a piece, I couldnt get mine off when i took the axles off for my 4.10 gears so said screw it and broke em beat em off. They cracked anyways.
smueller
57
Wisconsin
May 15, 2006
#10
  • May 15, 2006
  • #10
That's exactly what happened to me, they were impossible to get out! I made sure I fixed that problem when I put the new ones back in though. Next time they come out it will me much easier and they won't be destroyed. Glad to know I wasn't the only one who had problems getting these things out....
302pwr
37
edison,nj
May 20, 2006
#11
  • May 20, 2006
  • #11
What scan tool did you use for the abs? I have a autoxray EZ-SCAN 5000 and i dont think that has the abs feature.
P
Pennywise2
Banned
May 16, 2006
1,379
#12
  • May 20, 2006
  • #12
I got a ABS light on in my car two months ago and I took it to my
mechanic and he used the scan tool to check it and he says that
the ABS has internal failure and it's ruined.I need to know how do
you disconnect the brake lines from the ABS module? So,their is only
one bolt holding the ABS module in place? How long does it take to
take apart the ABS module and lines? Mike do you know? Thanks.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
