  • SN95 4.6L Mustang Tech
ABS Sensor
  • Thread starter Thread starter djfloyd
  • Start date Start date Oct 13, 2010
D
djfloyd
  • Oct 13, 2010
Hey all,
I have a '95 Mustang GT. Eight years ago I put my car in the ditch and the ABS sensor has been on ever since... until last week! I got my car washed at one of those automatic car washes and the sensor light went off. I pulled into a gravel parking lot and jammed on the brakes and my ABS suddenly worked again! I'm assuming this must mean that there is some sort of short circuit in one of the ABS sensors... since the ABS stopped working after my car had several hours to dry. I have no idea where the ABS sensors are, though. I tried looking in my repair manual, but it doesn't show me where they are at the wheels. Has anyone run into a similar situation? Any hints on exactly where I can find the faulty sensor??
Thanks!
Rob
D
djfloyd
  • Oct 13, 2010
I should probably clarify and say that the ABS warning light has been on ever since I put the car in the ditch... it was the ABS warning light that went off after I had the car washed... and came back on after the car dried.
Thanks,
Rob
D
djfloyd
  • Oct 13, 2010
Is the sensor located on the rear differential, as with the '91 Explorer in this video clip?
How to Unhook an Anti-Lock Brake Wiring Connector: How to Replace Anti-Lock Brake Sensors | eHow.com
D
djfloyd
  • Oct 13, 2010
I think I may have found what I need:
http://www.allfordmustangs.com/forums/attachments/2005-2010-mustang-gt-tech/43280d1208830101-r-r-rear-axle-abs-sensors-mustang-gt-wheel-speed-sensor-rear.doc
nancygrl
257
Oct 14, 2010
  • Oct 14, 2010
you probably had so much crud from ditching the car that it couldn't get a signal from the abs gear until you washed the mud etc away.
KBExperience
466
Houston
Oct 14, 2010
  • Oct 14, 2010
My '04 doesn't even have ABS
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 14, 2010
  • Oct 14, 2010
The sensors just need a good cleaning OP.
D
djfloyd
  • Oct 14, 2010
Yeah, I'm guessing it's a connection problem... but they stopped working after the water dried. Presumably the connector that is having problems got shorted together by the water when it was wet. I'll have to pull it in the garage tonight and pull the wheels off... need to figure out which one is the problem! =)
When did for make ABS standard?? I figured it was standard by '04...??
Mustang5L5
Mod Dude
Feb 18, 2001
43,344
18,074
224
Massachusetts
Oct 16, 2010
  • Oct 16, 2010
Ford did things weird. In 2004, to make the mustang cheaper abs was a 800 option.....but it was standard on 2003 gt premium cars for the same sticker price as an 04 without it.
In 2004, I was shopping for a new gt, and abs cars were not that common. I ended up buying an 03 just to have the abs.
As to the ops prob. I bet when he put the car in the ditch, he got mud and crud on one of the wheel sensors faulting it out. When he went through the car wash....the high pressure wash must have finally cleared it out.
SFStangGT
53
South Florida
Oct 16, 2010
#10
  • Oct 16, 2010
  • #10
My 2002 GT came standard with ABS..... But my ABS has not been working for about a year now also... So I guess FORD makes crappy ABS sensors and doesn't matter if the cars have it or now...
The ABS sensors are located just behind the rotors on all four wheels. There is a gear with several small teeth and a small sensor above it. If (when) the sensor gets dirty the ABS light comes on do to not being able to receive a signal.
ABS modules also go bad every now and then.
hotcobra03
poteet,tx
Oct 17, 2010
#11
  • Oct 17, 2010
  • #11
abs
i have stuff for 97 and newer..
maybe look thru this link for 95
Mustang FAQ - Wiring & Engine Info
D
djfloyd
#12
  • Oct 18, 2010
  • #12
Hotcobra03,
Thanks for the link! I found a page on that site that details how to troubleshoot '95 ABS problems:
Mustang 1994-1996 ABS Diag Info
I haven't tried it yet, but it looks promising! There is a procedure on there for getting the error codes out without a reader, which will be a plus. Thank you very much for this page!
Thanks everyone else for the replies! Very odd regarding ABS becoming an option in 2004... sometimes car companies do funny things...
hotcobra03
poteet,tx
Oct 18, 2010
#13
  • Oct 18, 2010
  • #13
abs
keep us updated...
there is alot on that link glad you found it..i was going to give just that link but as you can see its very useful...
Rejekt
546
Raleigh, NC
Oct 19, 2010
#14
  • Oct 19, 2010
  • #14
My light is popping on and off. I'm gonna clean mine too. It's aggravating.
ChillPhatCat
20+ Year Stangneter
Apr 22, 2002
409
65
48
Syracuse, NY
Oct 19, 2010
#15
  • Oct 19, 2010
  • #15
One of my sensors got busted in the gear upgrade... I've locked the brakes up 3 times since then... Not something that I want to spend money to fix but I probably should.
patman0911
2,287
Tuscaloosa, AL
Oct 20, 2010
#16
  • Oct 20, 2010
  • #16
djfloyd said:
Hotcobra03,
Yeah, good info in that link. I used that procedure to successfully diagnose my ABS system a few years ago - it's a shame the later ABS systems don't have that capability. I think the Haynes manual has a diagnostic tree for the ABS system once you know the codes.
As to ABS becoming an option, car companies do that all the time.
"Look, our car comes with [FEATURE X] standard!"
a few years later...
"Look, our car is the same price or cheaper* than it was last year!"
*[FEATURE X] optional
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
