AC Clutch Assembly
  • Thread starter Thread starter MahFiVeOh
  • Start date Start date Jul 11, 2005
MahFiVeOh
531
9
49
Ontario, Canada
Jul 11, 2005
  • Jul 11, 2005
My AC went for a crap today and noticed the clutch assembly is shot on the compressor.Is this something i can repair myself or is there a special puller to remove the clutch? It looks like a straight forward repair so i'd like to fix it myself.Any tips would be helpfull....thanks.
D
Daggar
3,902
  • Jul 11, 2005
Yes... you can pull it yourself. You'll need a set of long nosed reversable snap ring pliers. There's a snap ring inside of the pulley hub itself that often gets overlooked. Once out, the pulley usually comes free with little or no trouble. Occasionally, a pulley puller is required.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 11, 2005
  • Jul 11, 2005
The A/C clutch is about $100 new or you can buy a compressor from the junkyard with a working clutch for about $50. The puller is about $16 if you have to buy one, Autozone will rent you one for free.
The clutch hub is usually what fails, the rubber shock damper shears off from the steel hub and plate. The pulley turns, but the hub doesn't when you power up the A/C The hub comes off without much problem if you have the puller. You don’t have to do anything with the refrigerant (R12 or R134a), you can replace the clutch without draining and refilling the system.
A few simple electrical tests are advised before popping out the wallet to buy a clutch assembly. With the engine running, use a test light connected to the 2 wires on the A/C clutch harness to make sure you have voltage when you turn the A/C on. If the system is low on refrigerant, the clutch will not engage (safety feature, keeps you from burning up the compressor due to no oil). There is an aluminum canister on the firewall with a large hose leading to the A/C compressor. There is a pressure switch on it with a 2 wire connector: pull the connector off and jumper the wires. The compressor circuit will power up, and the test light will light if the electrical circuit is good. This test is also a good way to check the compressor & clutch if the system is low on refrigerant. You can jumper the wires and the compressor will turn if the clutch is good.
MahFiVeOh
531
9
49
Ontario, Canada
Jul 11, 2005
  • Jul 11, 2005
When i was checking it out there was chewed up rubber coming from the hub so i think it just needs replacing. .The system is fully charged, the air was ice cold before it died on me.Thx for help.
T
TheUser
1,859
Springfield, MO
Jul 11, 2005
  • Jul 11, 2005
where do you get the long nosed reversable snap ring pliers? Is that what you ask for at autozone?
D
Daggar
3,902
  • Jul 11, 2005
Yes... it's a common tool. I got mine at one of those (Autozone, Advance, Pep Boys, etc.)
The reversable part just lets you change the direction of the opening by moving the pivot pin (i.e. squeeze to open or squeeze to close).
MahFiVeOh
531
9
49
Ontario, Canada
Jul 14, 2005
  • Jul 14, 2005
jrichker said:
The A/C clutch is about $100 new or you can buy a compressor from the junkyard with a working clutch for about $50.......
I priced a new clutch....300 bux Canadian Ended up getting a junkyard compressor for 100 bux.Anyways i now have cold AC once again, thank god since its been hot as F the last few days (36C and with the humidex 44C).Thx for the info all.
trbkrb
1,976
Houston, TX
Jul 14, 2005
  • Jul 14, 2005
$300!!C Is that a new Ford part? I got a fully magnetic aftermarket replacement clutch from Autozone a couple of years ago for about $75US. It has worked great so far. Glad you got it swapped over. Try driving in 100 deg F heat with black leather interior, now THAT is HOT!
WTB Wanted - Foxbody clutch pedal
  • TTSaleen
  • Aug 4, 2026
  • Want to Buy
Want to Buy Aug 6, 2026
General karthief
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
