  • SN95 4.6L Mustang Tech
AC Compressor Causing Stutter in Power!
  • Thread starter Thread starter 300hpWRX
  • Start date Start date Aug 13, 2004
300hpWRX
Banned
Dec 18, 2003
20
  • Aug 13, 2004
I'm getting a noticable stutter whenever the AC Compressor cycles.
It happens between 2K and 3K, when either the AC or the defrost (uses AC Comp.) are on.
I can hear the click of the compressor cycling right when the stutter happens. It's just a quick dip in power, almost feels like the clutch slipping for half a second, just a little blip. And it happens about every 10 seconds or so.
Why is this happening, and how do I fix it???
(Car is a stock 99 Cobra)
C
clarkjr
716
NC
Aug 13, 2004
  • Aug 13, 2004
Most attentive drivers (like yourself) will notice a power dip/surge when the compressor cycles. It is possible that yours is a little low on Freon so you could have it checked but I always feel them kick off and on.
twogts4us
4,188
12
79
Dunedin, FL
Aug 13, 2004
  • Aug 13, 2004
You answered you own question - it's the A/C compressor causing parasitic power loss. It's quiet a draw on the engine and will cause this stumbling you are feeling. Well, not exactly a stumble, but kinda like you just threw an anchor out.
C
CatmanJJ
Captain Tangnet
20+ Year Stangneter
Feb 5, 2002
4,379
Maryland
Aug 13, 2004
  • Aug 13, 2004
I like it when the compressor kicks on when I'm running my A/C or defrost, my car idles rougher and the exhaust sounds more pissed.
'01 Steed
482
Michigan
Aug 13, 2004
  • Aug 13, 2004
First, this is totally normal.
Second, who cares? This will not happen at WOT, so what's the problem?
300hpWRX
Banned
Dec 18, 2003
20
  • Aug 13, 2004
But the power doesn't stay down, it's just one little blip of power loss every 10 seconds.
300hpWRX
Banned
Dec 18, 2003
20
  • Aug 13, 2004
[QUOTE='01 Steed]First, this is totally normal.
Second, who cares? This will not happen at WOT, so what's the problem?[/QUOTE]
This is not totally normal. The car should definately not do that. Maybe it's normal for Stangs, but that really sucks.
It doesn't happen at WOT, but it shouldn't happen at all. I should be able to cruise with the AC on without the engine farting every ten seconds.
I guess I'll just have to learn to live with it.
'01 Steed
482
Michigan
Aug 13, 2004
  • Aug 13, 2004
My bad, I didn't read the part about it happening every 10 seconds. Sounds like your refrigerant is low or you have a bad pressure sensor (hi or low?) Have it checked out. You may only need a recharge.
300hpWRX
Banned
Dec 18, 2003
20
  • Aug 13, 2004
That makes sense. Thanks.
Any idea where that sensor is? And would it throw a code if the sensor was bad?
M
  • mnky99
  • Sep 5, 2025
mnky99
M
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Dangerous High RPM at stop/ RPM Jump when switching to Neutral then dies.
  • 02torchvert
  • Dec 17, 2023
SN95 4.6L Mustang Tech Jan 3, 2024
Yel2002GTAuto
Y
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
D
Electrical Manual 2003 GT 4.6L coupe that will not start. Thoughts? Resources?
  • DapperFish
  • Jan 17, 2024
SN95 4.6L Mustang Tech Jan 22, 2024
PSKSAM2
P
