  • SN95 4.6L Mustang Tech
AC Problem?
  • Thread starter Thread starter pikuoff
  • Start date Start date Aug 30, 2005
P
pikuoff
  • Aug 30, 2005
I have a 2001 Mustang GT with about 35k on the clock. The other day, I was cruising down the interstate with the AC on and every 10-15 seconds or so, I would feel a little jerk or hesitation with a tick sound. I turned the AC off and it stopped. I put it on just defrost and then defrost/floor and it did it again. It doesn't do it with regular vent and just floor. The AC blows really cold still. What could be causing this?
On a side note, the light that makes the AC/Heat controls glow is out. Is there an easy way to replace that? Could it just be a fuse or would something else not be working if it was a fuse?
Thanks!
Mirrahasmycar
210
CT
Aug 30, 2005
  • Aug 30, 2005
that sounds pretty normal, its just the way the A/C works, the hesitation is fine as long as its not stalling out
squares98
852
Orange,ca
Aug 30, 2005
  • Aug 30, 2005
i hate ford a/c's but what can we do...
forpit2000gt
2,490
Columbia, SC
Aug 30, 2005
  • Aug 30, 2005
when you turn on defrost, the ac cuts on as well. it just blows out the defrost vents. It sounds like it may be a little low but may be normal.
P
pikuoff
  • Aug 30, 2005
I can understand when first turning on the AC but what about driving down the road? It does it every 20 seconds or so and you can feel it and hear it. I don't think that is normal?
forpit2000gt
2,490
Columbia, SC
Aug 30, 2005
  • Aug 30, 2005
ac cycling on and off usually means low on R134.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 30, 2005
  • Aug 30, 2005
Another vote for "low freon makes it kick on and off", get it checked...
P
pikuoff
  • Aug 30, 2005
Thanks for the help. I'll get it checked out this week. I didn't think it would be low since I just bought it last week from a Ford dealership and the fact that it blows ice cold. I was just hoping it was something I could take care of myself.
forpit2000gt
2,490
Columbia, SC
Aug 30, 2005
  • Aug 30, 2005
depending on the dealership they may take care of it for you. Someone with a set of guages can tell fast.
fudleyd
180
Littleton, CO
Aug 30, 2005
#10
  • Aug 30, 2005
  • #10
I had the same problem in my car--it would stumble occasionally with the ac on. It ended up being the ac compressor clutch or switch. I had it replaced under warranty and the problem has not returned since. Just another possibility...
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 30, 2005
#11
  • Aug 30, 2005
  • #11
Goog stuff guys!
nex2nutin
21
#12
  • Aug 30, 2005
  • #12
I agree with the a/c clutch. it might me sticking causing the belt to slip. It is supposed to cylce like you said thats how it regulates the pressure to the evaporator.
freon should never go low its a sealed system, if it low you have a leak that needs to be fixed.
forpit2000gt
2,490
Columbia, SC
Aug 30, 2005
#13
  • Aug 30, 2005
  • #13
it is a sealed system but if you don't run it for extended periods of time it can leak down slowly and when you start to use it again it will not leak. I've seen some that get a little gas in the spring and last for a year. If its low, ask them to add refridgerant with dye so you can find where it it leaking down.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
A/C blowing defrost
  • 70/04mach1
  • Jul 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
J
2003, 3.8l with air conditioning problems
  • Jimb0z '03
  • Nov 3, 2024
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2024
Jimb0z '03
J
1976 Cobra II fuse problem - Solved (I hope)
  • Rick Tanner
  • Jan 8, 2025
1974 - 1978 Mustang II Talk & Tech Jan 8, 2025
