  • 1994 - 1995 Specific Tech
ac question...
  • Thread starter Thread starter red dragon95
  • Start date Start date Aug 2, 2010
R
red dragon95
50
north las vegas
Aug 2, 2010
  • Aug 2, 2010
any one know what hp level the stock or stock replacement radiators are good up to with ac.my car only gets hot when the ac is on it gets rather warmer than id like without it but never gets as hot as with it on.my gauge gets all the way to the L in normal...so its damn hot.thanks for the help...and the fan turns to high when ac is on so its not the fan.
Bosko5.0
1,067
longwood, FL
Aug 3, 2010
  • Aug 3, 2010
How old is the coolant and is it a 50/50 mix?
Any aftermarket radiator should keep cool when the ac is on.
HISSIN50
34
129
Aug 3, 2010
  • Aug 3, 2010
Since you're in Vegas that's not surprising. What flavor of rad to use is your choice, depending upon fabrication skills, budget and so on.
Good luck.
R
red dragon95
50
north las vegas
Aug 3, 2010
  • Aug 3, 2010
coolant is a 50/50 mix..its new...new hoses,coolant,thermostat,and water pump.i noticed the ac clutch would engage and then disengage 30 sec after engaging..and the clutch would do this the entire time i was using the ac..i use the typical flavor of coolant..brand is peak coolant.
R
red dragon95
50
north las vegas
Aug 4, 2010
  • Aug 4, 2010
anybody got any ideas?
HISSIN50
34
129
Aug 4, 2010
  • Aug 4, 2010
What's the question? You're not rejecting enough heat. If it's triple digits out there, that's not unusual.
A
apt 94
Midlothian, TX near Dallas
Aug 4, 2010
  • Aug 4, 2010
I have that same problem. How can you tell if the fan kicks up to high speed when you ac is on? I drive with the windows down and AC off and it cools great, the needle moves a little when sitting at a light. when i get back to the house and it sits in the drive way for a minute or so after driving it and the needle starts moving fast towards the L.
Is the fan louder at the high speed or something like that so i can tell it in high?
HISSIN50
34
129
Aug 4, 2010
  • Aug 4, 2010
High speed is louder. You could test the wiring to confirm which speed is being engaged.
R
red dragon95
50
north las vegas
Aug 4, 2010
  • Aug 4, 2010
listen to the fan when it kicks on for normal cooling..then when the car is cold, and you are just starting the car for the first time of the day turn the ac on and you'll see the difference...it very noticeable.the fan goes immediate to high when the ac is turned on..
R
red dragon95
50
north las vegas
Aug 4, 2010
#10
  • Aug 4, 2010
  • #10
hissin50 i see your looking for a t5...my bud owns a shop and rebuilds t5's sells em for 900..and so you know encase you didn't the 94-95 t5 has a longer input shaft..in your top search bar go to scarperformance.com
A
apt 94
Aug 4, 2010
#11
  • Aug 4, 2010
  • #11
If i understand correctly it should be in high speed when the ac is turned on, and i should be able to tell by looking for continuity to ground at CCRM Pin 17 ?
A
apt 94
Aug 5, 2010
#12
  • Aug 5, 2010
  • #12
yesterday went and looked at the car again and when i started it was in high speed and i had the ac on you could tell by the sound then after a little bit it got quiter but i assume that it went into low speed for some reason even though i still had the ac on. Is that the ccrm dropping out of high speed for some reason?
R
red dragon95
50
north las vegas
Aug 5, 2010
#13
  • Aug 5, 2010
  • #13
if i am right,then the fan went to a lower speed because it didn't need to maintain that speed cause it reached the temp the ecm required.if i am wrong some one will chime in.my car does the same thing.
HISSIN50
34
129
Aug 5, 2010
#14
  • Aug 5, 2010
  • #14
The fan switched out of high speed while you still had the AC turned on?
toyman
1,944
54
79
Vernon BC
Aug 5, 2010
#15
  • Aug 5, 2010
  • #15
At idle and speeds up to about 45 mph the fan should stay on high speed with the AC on. The low speed fan is commanded by the PCM only when the AC is off and the coolant temp reaches about 220*F and stays on until the coolant temp falls to about 200*F. With the AC off the PCM will turn the high fan on at about 230*F.
A
apt 94
Aug 6, 2010
#16
  • Aug 6, 2010
  • #16
Yes, the fan dropped out of high speed with the ac on.
HISSIN50
34
129
Aug 6, 2010
#17
  • Aug 6, 2010
  • #17
When it does, what are CCRM wires 14 and 17 doing?
A
apt 94
Aug 6, 2010
#18
  • Aug 6, 2010
  • #18
will have to check that out either today or this weekend.
A
apt 94
Aug 8, 2010
#19
  • Aug 8, 2010
  • #19
14 v on 14 and 17 with ac on and the fan on, it sounds like it slowed down from when it initially turned on. then i was letting it warm up then i heard it get louder again then it sounded like it slowed down. then my probe fell out of one of the wires but on wire 14 it was 13.2v? does this mean anything? heard it slow down and speed up a couple of times. Then the wife reved the engine and it went to high again then after a few seconds of not reving it slowed back down
HISSIN50
34
129
Aug 8, 2010
#20
  • Aug 8, 2010
  • #20
Pin 17 should have showed continuity to ground when high speed is on.
If both fan speeds are on at once, the fan will run at kind of a middle speed and the system voltage will drop (it's not good for the fan or the electrical system).
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
D
Picked up Calypso 92 LX hatchback
  • Dakar09
  • May 18, 2026
  • The Welcome Wagon
The Welcome Wagon May 21, 2026
Dakar09
D
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
