AC/SMOG Pulleys
  • Thread starter Thread starter 95GTV8
  • Start date Start date Feb 6, 2006
95GTV8
386
Washington State
Feb 6, 2006
  • Feb 6, 2006
I'm going to be deleting my ac/smog as soon as i get my o/r h pipe in. Here is my question: I see smog pump eliminator pulleys for sale all the time, is it wisest to get a free spinning pulley, or just get a shorter belt? With the ac/smog removed, is it hard to get a belt in the right pattern, and is this the reason why people offer a smog eliminator pulley? Or is the smog eliminator pulley just a useless accessory. Thanks.
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Feb 6, 2006
  • Feb 6, 2006
Well, you figure a new belt is around 30 bucks at THE ZONE!!! and I don't know how much a delete pulley is but I'm guessing its more than that. It's very easy to find a belt that fits, just search these threads, I know there's been a billion of them. Plus, if you take the pumps off you have a nice weight reduction to work in. Just keep them around for resale purposes. Just my 2 sense.
89white50
440
central MA
Feb 6, 2006
  • Feb 6, 2006
I deleted my smog and ended up with a 71.5'' belt if i remember correctly. It took a few trips back and forth to the parts store becuase of belts stretching a little after firt warming up.
MrKwik
1,008
Kansas City, Kansas
Feb 6, 2006
  • Feb 6, 2006
I say that the eliminator pullys are a needless accessory unless you have a blower or something where you would absolutely have to have the belt in a certain configuration. Just get a shorter belt if your just removing the smog pump and you will be fine. If your doing A/C as well, use the FMS delete kit that moves the P/S pump up where the A/C was and you wont need a delete pully there either. The kit costs the same as the pully anyway and makes for a cleaner installation.
Looks like this....
JBeezy53
559
Sacramento, Ca
Feb 6, 2006
  • Feb 6, 2006
I think the pulley is ugly and unneeded. Also it looks a lot cleaner with no pump and a short belt. I just removed my a/c components and am
getting the fms kit. Well maybe, i might just go to manual steering.
$uperstang
476
Detroit, MI
Feb 6, 2006
  • Feb 6, 2006
I deleted the smog pump and A/C. For the smog pump I simply deleted it with no pulley. The reason they sell the pulley is so people can keep their stock belt. You can't, however just delete the AC/Pulley because something needs to be their up in it's place for the belt to route properly. So I purchased a UPR A/C elminator pulley looks cool. Many just get the FMS A/C eliminator as well which moves the pump up like the pic above. I did'nt like that because it put that big ass P/S pump in clear view and it's too big and bulky, I did not like the look.
My belt size was 83.5" with under drive pulleys.
L
luckythirteen13
648
Anaheim, CA
Feb 6, 2006
  • Feb 6, 2006
what would you do if you removed the a/c and ps pump? youd need some type of pulley on the driver's side
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Feb 6, 2006
  • Feb 6, 2006
Go shorter belt.
95GTV8
386
Washington State
Feb 6, 2006
  • Feb 6, 2006
thanks for the info guys, i was hoping i could get away with just a stock belt, but if i need a pulley in that region, i will look into the UPR or the FMS!
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Feb 6, 2006
#10
  • Feb 6, 2006
  • #10
i hate the idler pullies, useless and takes up space, i'd rather have the P/S moved up. I am going to delete my smog and move the P/S up when i do my motor swap. should look much cleaner, without the big fat black ac line and the little one in front.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
V
Okay for smog pump to spin?
  • Valicy
  • Sep 28, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 28, 2024
AeroCoupe
