AC Vents
  • Thread starter Thread starter asecretfile
  • Start date Start date May 16, 2007
asecretfile
228
  • May 16, 2007
Gonna remove the middle AC vents and put a couple gauges there...what's the best way to get the vents out? Was working on it a little yesterday and noticed they're in there pretty good
Thanks
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
May 16, 2007
  • May 16, 2007
simply pull out the two vents they are held by two tabs on each end, then GENTLY pull the tabs out (on bottom and top) so you can remove the vent cage. I had to cut the vent tube (black part behind the dash) so I could install the gauges properly.
TheBocSez
652
Converse, TX
May 16, 2007
  • May 16, 2007
The actual vents themselves just pull out. The bezel that holds them in is held in place by clips. GENTLY pry the tabs with a flathead screwdriver and pull and it will come out.
asecretfile
228
  • May 16, 2007
So the vents tabs are on each side and the cage tabs are top and bottom?
Thanks again
Boss 351
Jul 13, 2003
2,433
23
48
Canada
May 16, 2007
  • May 16, 2007
yeah just pull the vents out (tabs are on each side) and the bezel (or cage) tabs are on the top and bottom, they break easily so go easy on them lol
asecretfile
228
  • May 16, 2007
Ok cool thanks...one of my gauges will be a water temp gauge...are those fairly easy to connect up?
t/y :SNSign:
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
M
Idel control valve
  • miser143
  • Oct 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
General karthief
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
