Accel Ignition problem?
  • Thread starter Thread starter bradranger
  • Start date Start date Feb 2, 2004
bradranger
50
Hollywood,Maryland
Feb 2, 2004
  • Feb 2, 2004
I bought an Accel 300+ ignition from a guy at the track. I got it home and put it on and the car runs a little rough in idle and driving in the 1500-3000 rpm range. The guy told me how to install it. But I do have one question, there is a green wire on the igniton box that isn't being used. The guy told me he didn't know what is does or where it goes. Could this be my problem? I know its not the coil cause I unhooked the box and left the coil in and it ran fine.
bmorrisj
449
Buena Park, CA
Feb 2, 2004
  • Feb 2, 2004
green wire= tachometer
http://www.mrgasket.com/accelpdf/300+trouble.pdf
http://www.mrgasket.com/accelpdf/FordEECIV.pdf
P
PRO50SC
1,012
Olney, Maryland
Feb 2, 2004
  • Feb 2, 2004
What about your idle and mid range problem, were they there before. Can you plug in your stock stuff and does the problem go away. If so, than something is wrong with the stuff you bought or it's not hooked up right. A lot of times you can contact the manufacturer and get instruction sheets form them. Just another option for you.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
