Accessory mounting Help
  • Thread starter Thread starter blandq
  • Start date Start date Jan 11, 2006
blandq
146
Houston Texas
Jan 11, 2006
  • Jan 11, 2006
289 ('64), AC Sanden, Pwr Sterring, Flex Fan, Alternator, march v-Bert pullies all the way around.
I run the TCP R&P Power Setup and on original install reused the Eaton Pump with integrated reservoir. I knew it would last long in a roller motor with a 2800 stall and alas it has died. I want to go to the KRC pump.
I have never completed the Vintage air installation due to some not insignificant interferance with the compressor mounting and old sterring pump but also because I was not thrilled with the way Vintage Air designed their mounting Bracket (attached to several water-pump mounting points.....not optimal.
So....., I was looking for come input and pictures from several of you to help me optimize the solution for mounting the AC compressor and KRC Power Steering pump in the '64.5 coupe/289 situation I have.
Thanks;
-Q
  • dan50
  • Jul 18, 2026
dan50
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
