will a spacer help out at all with the accufab plenum. i have an opportunity to get a 5/8 spacer (i think that is the size) for $10. would it make any better flow?
I agree with what you said about the intake spacers. What I'm curious about is this "weiand street single four barrel tunnel ram" intake you're talking about. I take it this is not something for the 2v 4.6ltr GT's ?billfisher said:assuming your runners on your intake have the volume and taper to support it, adding spacers helps shift max rpm torque(hp) to a higher rpm. there is a rusulting drop in low rpm torque as well. i intend to add a cowl hood or scoop to put a 2" spacer on mine. drag racing uses high enough rpm band to benefit. the plenum acts like a capacitor for the runners. the more they can draw from the more they draw. when ford designed the original 4v intake they designed it with less than half displacement volume to retain low rpm torque. remember the wall is the runner length,volume and taper limits. just look at a carb tunnel ram intake. huge plenum volume with large cross section high taper runners. by the way the best torquing horsepower intake available for the street is a weiand street single four barrel tunnel ram. it keeps all low end torque and makes power to 7500+ rpm's.
Dark Knight GT said::offtopic:
Forpit, anyplace I can find out more information on the Reichard racing intake ? I've heard the complete intake with install kit is like 2,000 dollars. Is this true ? Thanks.
hotmustang331 said:Weiand intake manifolds are ONLY for pushrod motors like the Ford 302s and Chevy 350s. Weiands seem to be good intakes but I use edlebrocks Vr Jr intake for my 331. Its powerband is from 3500-8500+. I dont buy the whole idle-7500 thing...maybe on certain setups with the right cam and heads it can make power off idle...but it sure as heck wont pull to 7500....and if the cam and heads are setup for 7500RPM it will NOT make power off idle. The powerband stuff advertised cant be taken literally alot of times and completely depends on your setup...especially the weiand. BTW My heads are setup for 3500-8500...but my cam is setup for 3000-6800. It pulls to the 7500 limiter with ease though.
As far as the spacer, I think Csledd has one with her aftermarket plenum and heck she made 270RWHP W/O cams...so i doubt it will hurt lol.
hotmustang331 said:Please dont go carb on a modular...you can make more power with EFI (with FI anyways) and tuning is a sinch.
forpit2000gt said:Not sure about the Weiand intake, haven't seen that yet. Reichard racing makes a 4bbl intake for the 2v and Hogan makes them for the 4v. I am going with one of these setups.
forpit2000gt said:This is application only, that is not a true statement. You can make equal or more power with a carb. It is just different.![]()
