  • SN95 4.6L Mustang Tech
Accufab Plenum Bolt SNAPPPEDD
  • Thread starter Thread starter bgbg22
  • Start date Start date Oct 22, 2007
bgbg22
23
  • Oct 22, 2007
Ok so im installing my accufab plenum with 75mm tb on my 00 gt. And a bolt snaps in ****in half, on the vaccuum housing section. There is a top and bottom bolt, so i screw in the top bolt, and it seems fine.
I tried everything, drilling it, taping it out, n the tap ****kin brookeee in half. Any suggestions, should i just go to a local mechanic. The car runs fine, but i will def need that bolt to be in there long term.
OO yea, do not get the JLT COLD AIR KIT, it was the biggest bitchh on earth to install, n it practically rides on ur fender wall by ur front right tire. It is wayyy to bigg, and the maf has to be repositioned in the fender wall. SOO MUCH BULL****
lvmustanggt
721
Las Vegas
Oct 23, 2007
  • Oct 23, 2007
Z
ZakeriD
112
  • Oct 23, 2007
x2....
DTNODYA
831
  • Oct 23, 2007
Take a picture of it ... we could help you better if we saw the bolt ..
The intake manifold has threaded inserts that the bolts screw into. I bet you're talking about the single bolt (aside from the 4 main ones) right? I almost broke mine accidentally because it didn't feel like it was tight enough. But yeah, pics would help a bunch.
kalvick
352
Norwalk, CT
Oct 24, 2007
  • Oct 24, 2007
yea, the same thing happened to me. you will have to drill it out. my bolt was really stuck in there so i was a bitch to get out. but you will have to use force and you may ruin the hole. but the plenum is aluminum so while you screw it out with the hand tapper, the grooves in the screw hole are gonna get really messed up. since its so soft. there is no way to cleanly get it out without ruining some of the aluminum.
I bought the recoil thread repair kit.
size m6-1
part no 35060
drill: 6.3MM 1/4
Lot number 412395
it seems you know what the tools and tapper are, but for everyone else here, here is an image of what i got, i was about 40 or 50 bucks. http://www.postnetlnc.com/Z400/TechTips/Tech01/Helicoil2.jpg
nyuk98gt
1,427
Chesterfield, MO
Oct 24, 2007
  • Oct 24, 2007
bgbg22:
If you can, use a Dremel to cut a slot in the remaining bolt. Once the head is broken off, there is not much holding the remaining stud in place so it can be (fairly) easily removed with a screwdriver. It will be a pain but you should take the TB/plenum off as a complete assembly and head to the workbench. You may be able to get at the bolt from the plenum side.
HTH,
Chris
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
  • Locked
Expired 00/03 Cobra Clone Fully Built Street/track Monster Kenne Bell
  • BOSS GT
  • Aug 20, 2013
12K
SN95 Mustangs For Sale (1994-04) Oct 29, 2013
BOSS GT
N
Just installed JLT CAI, Accufab Throttle Body and Plenum
  • NewMStang
  • Jun 21, 2009
2K
SN95 4.6L Mustang Tech Jun 22, 2009
NewMStang
N
Accufab add on idle problems
  • SROBERTLAW2003
  • Apr 30, 2008
3K
SN95 4.6L Mustang Tech May 1, 2008
SROBERTLAW2003
Wild Idle After Accufab 75TB/Plenum and JLT CAI
  • bgbg22
  • Oct 28, 2007
3K
SN95 4.6L Mustang Tech Nov 4, 2007
R.J.
