ACT sensor thread question
  • Thread starter Thread starter RYC CUKR
  • Start date Start date Dec 10, 2005
RYC CUKR
1,437
Orlando
Dec 10, 2005
  • Dec 10, 2005
What is the thread on the ACT sensor? is it 3/8" npt or something. I am gonna drill and tap the ACT boss on an explorer lower is why I am asking.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 10, 2005
  • Dec 10, 2005
Take the sensor to Home Depot or the hardware store. They will have a pipe fitting you can thread it into to check the thread size.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Dec 10, 2005
  • Dec 10, 2005
I would just mount it into the air intake tube ahead of the throttle body. That's where it is on most vehicles.
The way Ford mounted the ACT low on the engine isn't exactly the greatest place to get a reading
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 10, 2005
  • Dec 10, 2005
Amen to that statement, here's the how to do it...
The best spot for the ACT is the air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
6 ft black 18 gauge wire
6 ft green 18 gauge wire
6 ft 1/4" heat shrink tubing
1 ft 3/16" heat shrink tubing
Measure the 2 extender wires & cut them to length, crimp one set of pins on them. Then mate up the extender pins with the wiring harness & slide the 3/16" heat shrink tubing over them & shrink the tubing. Then slide the 1/4" heat shrink tubing over the pair of wires and shrink the tubing. When you are done you'll have about 1" of wire left without heat shrink tubing on it to strip & crimp the new pins on. Stick the new pins in the old connector shell, assemble it and you are done. It looks as good as factory. Some wire loom can be used to enhance the "Factory Look".
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 10, 2005
  • Dec 10, 2005
....or you can simply cut and solder in additional lengths of wire and insulate with heat shrink. Cover the wiring with the factory black 'corrugate' loom and it looks completely stock. That's the approach I took when I moved mine to the air intake elbow in front of the throttle body.
No performance benefit to moving it -- it's just a little less risky than drilling and tapping those crappy lower castings...
bubba-dough
1,044
Indiana
Dec 10, 2005
  • Dec 10, 2005
I didn't do mine, my engine builder did, or I could tell you.
A
andrewVA
20
  • Dec 11, 2005
Disregard, I got it.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Dec 11, 2005
  • Dec 11, 2005
9/16" drill and 3/8" NPT tap - regardless of where it goes.......
RYC CUKR
1,437
Orlando
Dec 11, 2005
  • Dec 11, 2005
Thanks for the info guys.
R
Electrical Act
  • Robman8028
  • Jun 15, 2025
Fox 5.0 Mustang Tech Jun 16, 2025
General karthief
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
ACT sensor in plastic charge pipe
  • 92Rustang
  • Jul 23, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2024
92Rustang
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
