Add A/C.......
Ive thought about the same thing man. My hatch had factory AC but the compressor was removed and the lines were cut at the firewall. The bracket for the compressor is even still there. Theres jsut a million other things going on right now. (clutch, misfire at idle, some codes, etc) that require my attention first. To make matters worst I work till 5 and then have to be home for 530 and I cant really get much done at home cuz my drivewat is at about a 35 degree angle.
There was an artical in 5.0 mag about an aftermarket 134a system that by far outperforms the stock R12 system. If you get all junkyard parts, it might be a real headache because who know's what is good and not and how much more life it has. Filling the R12 system with R134a when done properly will work but will not cool as well because R134a requires higher pressures to be efficient.
jays88notch said:
well the thing is is that my stang never came with A/C so is it only the heater core then just turning on the compressor is there more to it then that?
You will need the entire heater box (which houses the evaporator and heater core), the lines that go from the firewall to the compressor (which you will need) and the condensor (you will need, in front of the radiator). The lines also have a canister on them (sorry, terminology escapes me), but that is usualyl one-piece. There are different brakcets for the power steering pump/compressor. A wiring harness for the compressor. A WOT shut-off relay. HVAC control panel inside the car. And of course any other brackets and screws.
The work behind the dash is the most difficult and time consuming.
89MustangGX said:
I'm no HVAC pro, but I believe in a properly designed system, the new refrigerant can outperform the R12.
The heat exchange properties of R134A are not as good as R12, especially at low airflow. Therefore, it is impossible to outperform.
Any A/C technician will say the same. If possible, stay with R12. Try the Forum at Aircondition.com
The canister is called an Accumulator.
The line from the condenser to the evaporator is called a liquid line and contains the fixed orifice. The suction line goes from the accumulator to the compressor.
For a brief explanation of the A/C system in a Fox Mustang, see the section "Introduction to the A/C system" at the below URL.
http://www.veryuseful.com/mustang/tech/general/R12-to-R134A-Conversion.html
Someone else trying to add A/C...
http://www.foureyedpride.com/phpBB2/viewtopic.php?t=18744
