Well the iac holes in the throttle body supposedly the culprit, but i massaged them pretty good and it still did it, then i added the hole.nice....so you actualy got the whistling to stop?....easy?,im getting ready to do same thing??
read that it was the edges ya,havnt heard about the hole?....where did you put the hole if you dont mind me asking?....mine whistles like crazy.Well the iac holes in the throttle body supposedly tbe culprit, but i massaged them pretty good and it still did it, then i added the hole.
The 65mm frpp had the hole in the left side but i put mine on the middle right to disrupt the air flow around the iac ports.read that it was the edges ya,havnt heard about the hole?....where did you put the hole if you dont mind me asking?....mine whistles like crazy.
Many may not like this approach but i feel i did it safely. I stuff the intake with a towel, placed the 75mm gasket on, drew with a pencil around the edges, took the gasket off and used a dremel to port match the edge and went a little inside the intake. Then used a vaccum with a tube piece, then pulled the towel out, used vaccum a little more, then a light damp towel rub, a little more vaccum and then reinstalled it. I could massage the inner a touch more if i get bored and want a project, it was real easy.read that it was the edges ya,havnt heard about the hole?....where did you put the hole if you dont mind me asking?....mine whistles like crazy.
The frpp one came with the hole so they knew something about it....lolthanks for info...hope i can fix mine!....people think i hav a supercharger!
