adjusting brake pedal height?
  • Thread starter Thread starter DukeGnarley
  • Start date Start date Oct 6, 2004
DukeGnarley
597
Auburn/Ellensburg, Wa
Oct 6, 2004
  • Oct 6, 2004
Ok, i just installed a power brake booster i got from mustangs unlimited. My only problem is this, the pedal has a lot of play in it before it actually begins to brake. If i adjust the pushrod thing so the pedal sits a bit higher than the gas pedal, then i have to reach really far before i get to the part of travel where the brakes kick in. if i move the pedal up much higher than that, then it will be a pain to get to (especially with my stock steering wheel in the way of my leg). do any of you know of a way to reduce that play before the brakes start to work?
just to clarify, the brake pads are all adjusted out properly, and the connection from the brake pedal to the power booster is solid. Once the pedal is pushed in enough, the brakes feel solid.
66P51GT
721
Cerritos, CA
Oct 6, 2004
  • Oct 6, 2004
Sounds like you may have air in the system. Re-bleed the brakes and see if that helps at all. I've replaced two complete brake systems and usually have to do mine 2 or 3 times before the pedal is solid.
A brake shop can power bleed the system for about $50 just to make sure.
DukeGnarley
597
Oct 6, 2004
  • Oct 6, 2004
brakes are bled properly, had a reputable shop do it. It's not that the brakes feel spongy at all, it's that the pedal seems to ride higher than the point where actual braking begins.
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
R
Brake Master Cylinder replacement steps for 2016 S550?
  • Reybeast
  • Dec 16, 2024
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Dec 21, 2024
89ripper
