Adjusting Roller Rockers
  • Thread starter Thread starter 1992blkGT
  • Start date Start date Feb 24, 2004
1992blkGT
523
Beaverton, OR
Feb 24, 2004
  • Feb 24, 2004
I have the Trick Flow Street Heat H/C/I Kit, and I finished installing the heads and started on the 1.6 roller rockers. Anyway, I've never adjusted roller rocker before, and I just want to see if I did it correctly. We started at TDC on compression stroke, and then tightened the roller rocker bolt down until it stopped wiggling, and then 3/4 turn after that. We turned the crank 1/4 and worked on the next set of roller rockers for the firing order until we finished. We then kept turning the crank and making sure none were loose, and if they were we loosened them completely, tightened the rocker bolt until they stopped moving, and did 3/4 turn. We kept this up until none of the rockers moved around too much. Is this correct? The instructions were confusing and my brother and I don't know how to do this sort of thing. Oh and after they all stopped wiggling around we tightened the hex key in the center of the bolt to hold it in place. Thanks for any help!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 24, 2004
  • Feb 24, 2004
Check this out...
http://www.trickflow.com/product/twisted_wedge/info_pages/twiswedge_inst_frame.htm
OLDJUNK93
77
kansas
Feb 24, 2004
  • Feb 24, 2004
i always tighten down the rocker until the pushrod stops wiggling or stops turning freely then another 3/4 turn. make sure if you use new hyd. lifters you prime them first or re-adjust the rockers again after you run it for a few minutes.
86gtriceeater
316
Whitewater, WI
Sep 23, 2006
  • Sep 23, 2006
i'm installing some 1.7 roller rockers anybody have some good install direction?
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
A
Resolved 302 still running after turning off ignition
  • AlexM556
  • Nov 14, 2026
Classic Mustang Specific Tech Nov 15, 2026
AlexM556
A
