  • 1994 - 1995 Specific Tech
Adjusting timing?
  • Thread starter Thread starter Guero
  • Start date Start date Nov 6, 2007
Guero
2,148
Nov 6, 2007
  • Nov 6, 2007
How do I adjust timing now?? I went carb and have a magnetic Pickup..... Do I have to disconnected anything to adjust timing?? Thanks.....
Guero
2,148
Nov 6, 2007
  • Nov 6, 2007
ttt
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 7, 2007
  • Nov 7, 2007
are you using vacuum advance? if so remove the vacuum line from dis. and set timing then replace your hose.
Guero
2,148
Nov 7, 2007
  • Nov 7, 2007
Magnetic Pickup...
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 7, 2007
  • Nov 7, 2007
just adjust at idle to whatever you want set at (12/14 degrees) base and lock it down then rev to 3,000 or so and see if you are around 32/34 degrees
P
porchstang
49
bakersfield
Nov 7, 2007
  • Nov 7, 2007
Guero said:
Magnetic Pickup...
Ok that is the pick up instead of points now is it a vacume or mechanical secondaries? Set timming to 12 degrees then bring up the rpm's to about 3k and see were total timing is it should be around 34 degrees total timing. If it isn't then bring it back down to idal and add a degree or two to bring the total to 34 degrees.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Monday at 11:07 AM
phil2001svt
Engine 1984 GT 5.0 Timing and Carb adjustment procedure
  • handymancanfixit
  • May 13, 2025
Fox 5.0 Mustang Tech May 13, 2025
limp
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
