No...at this point you will be fine with the stock 19's. 19s will support up to 300 N/A horsepower. At this point you are probably only putting out about 240.
Bigger injectors will hurt your driveability, cold start performance, and idle. Larger injectors perform sloppy at low load/rpm and dont get great fuel atomization.
You really want your injectors to see about 80-90% duty cycle at WOT. If you are seeing less than that...like you would with a larger injector....you will most likely see a drop in performance, driveability, and mileage. Stick with the stockers right now.
