Advice after break down.
So the back storry and info.
I had an accident. 1995 gt aode.
Is this a comon issue ? Anyone know what could have made this happen ?
Has it happend to annyone els?
Piston 8
Bone stock internals.
Smog delete
Tune
Cold air intake
410 gears
98 pump gas.
No h/c/i
No boost
No nos
Incident happend on acceleration.(no kickdown )
Now the engine is apart and time to rebuild.
And i have no hp number more like a feeling goal.
Im thinking hci a decent one (budget friendly maybe?)
Converter(i think it translates too)
And a sc for maybe 0.6 bar.
what are decent uppgrades to do wile the motor is out? Or needed? Maybe some good fixes and uppgrades wile im doing it?
Also if u got an educated guess on the error that caused this feel free to guess all help and perspektives are welcome.(got a decent list of couses my self)
Gonna be a fun car for goofing around and redlight races/weekend car.
If you know what the adderad side skirt and front bumper is id like too know that also :D
Sorry for bad english and gramar misstakes.(and long post)
Don’t know what you’re asking here.
“Is this a comon issue ? Anyone know what could have made this happen ?
Has it happend to annyone els?”
Why not just rebuild what you have (if the block is in good shape) with a decent set of pistons and go through the stock heads. Put a blower on it with the right size injectors and tune it. Should make around 350 rwhp or a little less. To put into prospective you car stock was 225 crank hp.
For me this would be a really reliable setup and not cost you and arm and a leg.
First thing I would do is check the existing block to see if it's rebuildable, compare rebuild costs to a crate engine with updates like aluminium heads, cam that works for the driving you will do, being in another country is gonna dictate costs/availability.
Perhaps hook up with other American car owners at a show or local club on how they tackled an engine rebuild.
Well a stupid question maybe. Do anyone know the oem stock piston weight with pin ? Since i need new pistons.
For anyone wanting to know it was an injector gone bad.
Cylinder 7 and 8 have had issues.
And it seems to be some alcohol etching i think it is called on the block and piston 7 has some symptoms as well.
So all pistons will be changed and injectors and other stuff aswell.
(Yes i can weight them my self but i work away from home and what to order before i get home if i can get the info)
My old thread. But a conclusion have been found why it happens. If anyone else have the same issue on ther journey.
Acording too machine shops where i live (translation might be wrong) but its called alcohol etching. So i rebuilt everything with new parts and goddies.
