AFR Table Tuner Studio
Finally got my car idling great and good throttle response. Only problem is that it has trouble reaching the target afr from the table. Also, Im guessing that the VE table should never be over 100?
  • CurrentTune.msq
  • TunerStudioAppDebug.txt
Nope, reaching target means tuning the VE table so it will. The VE value can go up to 255 depending on how the tune is setup. The ve value only hold credence to actual engine VE if all the injector settings and absolutely spot on and the tune is setup correctly.
basically dont read into it too much.
you did not post a datalog file
