  • SN95 4.6L Mustang Tech
After PI intake swap, 3 code ?
  • Thread starter Thread starter Killa
  • Start date Start date Oct 28, 2007
Killa
1,006
56
49
Oct 28, 2007
  • Oct 28, 2007
These are 3 code I found on my 98 gt.
P0500 - Vehicle Speed Sensor fault.
P0171 - System Too Lean - Bank No. 1.
P0174 - System Too Lean - Bank No. 2.
new plug and wire with 2 new bosch o2 sensort, my car is smoke alot the other day and water was coming out the tail pipe, I lucky enough to fix it with head gasket repair, now it no or very little smoke when start up, after its warm up no more smoke . Could it be water destroy my o2 sensort ?
and my idle is around 800, when I put the gear to neutral to brake the car, then edometer is point at 1500 and after the car complete stop, few second later it drop down to 800 ?
thanks
Killa
1,006
56
49
Oct 29, 2007
  • Oct 29, 2007
any one ?
LI98GTStang
1,715
L.I., NY
Oct 31, 2007
  • Oct 31, 2007
Did you get coolant down in the engine when you took the PI intake off? I did and used a wet/dry vac and let it run to burn the rest off.
Killa
1,006
56
49
Nov 1, 2007
  • Nov 1, 2007
I clean every thing up nicely.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
