- Feb 16, 2004
- 1,025
- 0
- 0
If the axles were made strong/well enough, does spline count really matter then? Also, would you have faith in some aftermarket 28 spline axles from moser or strange?
90mustangGT said:When axels break, they usually break at the shaft near the carrier. I have never seen a axel with the splines stripped off of them.
I think the logic is that more splines are a little stronger, so while upgrading everything, why not. However, I bet with 28's, you will break the rear end before stripping the splines.
RacEoHolic330 said:I went right ahead and got 31 splines when i did my posi install. I figured I might as well do it right the first time if I plan on making real big power in the future
