aftermarket axles with sn95 brakes
nocaryet
12
I know what your thinking not another 5 lug 4 wheel disc question, but i searched and found nothing. I also looked here http://svo73mm.cjb.net/ and it doesn't say anything about using aftermarket axles (like moser strange etc) with sn95 brakes. Since most aftermarket c-clip axels keep the stock track im guessing you use the north racecar brakets, but what about axles with c-clip eliminators? I would like to use something like moser 31 spline axles with c-clip eliminators when i upgrade to sn95 brakes. Would this work? What caliper mounting bracket would i use?
thanks in advance
Good question. You can get the Mosers and others in both the Fox and SN95 lengths, so if you keep the C clips, you can go either with the SN95 setup or use the North Racecar brackets. I do recall someone asking about the c clip eliminator kits with disc brakes, and I don't recall exactly the outcome, but I searched and found this thread by searching "disc eliminator". Maybe it has some info you can use.
http://forums.stangnet.com/showthread.php?t=368085&highlight=disc+eliminator
Good luck!
