aftermarket chip?
It would probably help, but if the car is running well right now then it wont be worth it.
Or.......you can try it yourself. Check out this thread I started about emulating EFI with a PC. Through the course of the thread, it als came out that you can do chip burning just like the pros do. Initial investment for the equip is about what a custom chip costs.
I have 3 UV-erasable EPROMS I found in electronics just thrown away.
Nope... The only reason to get an aftermarket chip on a mild n/a combo, IMO, is if you're having drivability problems or just can't figure out a wacky fuel curve. Otherwise, adjust the AFPR and set your timing and let the stock computer do the rest.
Chris
Most of the Fox3 cars can be made to run pretty well without a chip. If the car is running OK already, either skip the chip, or take the car to a dyno and get a proper custom tune, which probably will be worth it.
-Matthew
