Aftermarket Head Unit on Mach 460
rleyba said:
Thanks for the reply. I have a 03 Mach and it's 5-sp, and I will also be using a 4ga power wire, hopefully I won't have a hard time getting through the firewall. How hard is it to remove the panels or scuff plates? Also did you run the remote wire parallel with the power wire? Thanks again! :D
The scuff plate just pulls off and the kick panel has a little push pin you gotta pull out then pull it back towards the back of the car. I ran both the wires down the same side of the car. They are ok together.
