Aftermarket Head unit on Mach 460
MGSTANG
383
Palm Bay Fl
Has anyone ever put an aftermarket headunit in a newer mustang with a Mach 460 without rewiring the hole system? The older stangs have a wiring harness, but the newer ones dont that I know of. My car is an 04
That doesn't help me any. When I last checked it had to be rewired, I was asking if there's been any changes. The Mach 460's with the 2 seperate radios can have an aftermarket head unit, the ones with the singles can't. That I know of
Aftermarket hu
I know this doesn't help your question much but how do you use an aftermarket head unit (rca level preouts not speaker) on mach460 with the separate cd player?
Is there an adapter that let's you use the LINE level outs of your deck??
Thanks
p.s there were some interesting diagrams @ flemworld.com perhaps they may help you out if your better a deciphering them than I am.
Ryan
As far as I know it's been explained in more than one thread that you need to use a Metra wiring harness and that you should call Metra to find out exactly what you need.
What year is your Mustang? I just replaced the head unit on my '01 Mach 460 with a Kenwood MP3/Sirius head unit and it sounds pretty good. If you have an '01, I can hook you up with all the part numbers I used.
Justin
Justin
Does the 01 come with 2 different decks, or one big one? Mine has the Mach 460 6 disc in it. I don't want to rewire the hole system because I like the fact that I have the 8 speaker mach system. I just want my pioneer 9300 headunit in there to help with the lows for my subs. I already have it bought so it's just sitting around waisting the 4 year warranty on it. Been sittin since December. If I rewire it, how do I still use the door tweeters, and back tweeters. Do they have there own channel on the stock deck, or does it just tap into the door speaker wiring.
The latest is that there was a "silent" harness change from '03 to '04 - Metra is working on a harness, but at this time there isn't one.
I suggest waiting a month or two before making a move - maybe one will hit the market soon (Metra "amp integrator" plug for 2004 will be part # 70-5520 i believe).
Not quite true - a set of harnesses and an integrator exists through 2003 - in '04, Ford made a harness change that they didn't notify the aftermarket about.
Be patient, it'll come. soon.
Here's the scoop on the '01 Mach 460 from my research. Basically, your system consists of 3 amps. One runs the front woofers, one runs the rear woofers, and one runs all 4 tweeters. The problem is that the one that runs the tweeters is actually inside the Mach 460 head unit. Therefore, you need to rig your aftermarket head unit up to send an amplified signal to the tweeters with a high-pass crossover on it and use the sub out on your aftermarket unit to send an unamplified signal to your 2 sub amps with a low-pass crossover on it. Here's what I used:
- Scosche Sound Kase SKFD223 - $25
http://www.cardomain.com/shop/item.pl?sku=SCOSKFD223
This installation kit fills the hole left by the single din aftermarket head unit. It replaces the empty space with 3 CD trays, which are quite convenient.
- Kenwood Excelon KDC-X579 CD/MP3/WMA Receiver - $178
http://www.techronics.com/index.cfm...ay&Product_ID=914&CFID=47027&CFTOKEN=74911908
I picked this head unit for 3 reasons. 1) I wanted MP3 functionality. 2) I wanted Sirius compatibility. 3) I wanted a sub out to run to the Mach 460 amps with a low-pass crossover on it.
- METRA 70-5519 Harness
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=265-790
This is the ONLY harness that will work that I have seen. I purchased the Best harness originally, and it did not have the correct connections.
If you need help getting to the stereo, check out the beginning of this tutorial to see how to get into the center console area:
http://www.stangnet.com/tech/speedsound/ssv.html
Basically, all you need to do is take the Metra harness and connect the sub out from your aftermarket head unit to the RCAs on the harness. This handles the subs. Then connect the Front L+/-, Front R+/-, Rear L+/-, Rear R+/- as labeled from the aftermarket head unit to the Metra harness. This will send an amplified signal to the tweeters. Put all of the grounds together and wire the amp turn-ons into the ignition power lead. This should do the job. When you power the new head unit on, you will need to set the crossover on your sub out as needed to only send lows to your sub amps.
This worked for me immediately when I hooked it up and it sounds pretty good. I got a bit of increased sound quality out of the subs, but overall, it still sounds like the Mach 460 system. Let me know if I can answer anymore questions for you. Many people in this forum helped me gather all of this info and I'm more than happy to pass it along!
Thanks,
Justin
MGSTANG said:
So the conclusion I came up with, is wait a few months?
If it's an '04, if you're not comfortable going in and splicing wires, I'd hold out a bit.... I *doubt* it'll be a few months.
I'd call Metra at 800-253-TECH and see if they have any updated info on when a harness will be available for your car.
Basically, if you have an '01 and are interested in setting it up the way I did, you'll be able to do it with no problems. No new harnesses will be coming out for older Mustangs, just for the '04s. If you have any specific questions about my earlier post, let me know and I'll be glad to help ya out.
Justin
Justin
But the original poster has a 2004 Mustang...
