  • 2005 - 2009 Specific Tech
Aftermarket shifter buzz?
  • Thread starter Thread starter mltdwn12
  • Start date Start date Feb 13, 2007
mltdwn12
Peoria, AZ
Feb 13, 2007
  • Feb 13, 2007
Anyone install an aftermarket short throw shifter and get a buzz in the middle of the rpm ranges? I put a Roush shifter in my 06 Roush. It gets annoying. I called Roush and they said that's what you get with a short throw shifter Friend of mine had a short throw put in his Z06 and it was perfectly quiet. Over at another Mustang forum I heard guys with a B&M and another compant I can't recall had the same thing. Anyone install one that didn't make noise?
Craig
BlackRod
55
Southern California
Feb 13, 2007
  • Feb 13, 2007
I installed the B&M shifter and the only noise I get is a creak when I gas it or hit the brakes. Don't know where it's coming from, but it bothers me....no buzzing though, just the creak.
M
mustangracer
360
Southern California
Feb 14, 2007
  • Feb 14, 2007
I've got a B&M shifter and found the squeak. Turns out the body end of the shifter moves slightly with engine/tranny movement. This causes the stainless body of the shifter to squeak against the washers installed between the shifter body and the retaining nuts. B&M supplied brass washers originally, if these are replaced with steel it gets louder (ask me how I know). Next time I'm under the car I plan on adding some teflon or similar washers to eliminate it.
L
LILJOEPRO5.0
Banned
Jun 11, 2006
18
  • Feb 26, 2007
When these shifters are made all of the rubber is removed in order to make them shift positively. If you want a quieter shifter, then you want one that shifts worse. That is the trade off of aftermarket shifters and other aftermarket parts that improve the performance. If you want a quiet car that rides smoothly and doesn't make any noise and doesn't use much gas it is best to buy stock parts.
SnakeByte
Long Island, N.Y.
Mar 4, 2007
  • Mar 4, 2007
I put the Roush in to. I also have the Roush billet handle & kob. The billet handle comes with a rubber spacer. I get no buzz with it.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 6, 2007
  • Mar 6, 2007
how is the throw in the roush shifter?? the handle looks VERY long!!! almost taller than stock...
mltdwn12
Peoria, AZ
Mar 6, 2007
  • Mar 6, 2007
The throw is real short. I also have the roush shifter ball. That was my first thought as to the cause of the noise, but it makes the noise with no shift ball or adapter installed. I did talk to Roush again and they said they have a newer design that doesn't buzz. I ordered one and they will give me credit on the old one once I send it back to them.
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
Drivetrain 5 speed will not shift at all
  • Meadecomustang
  • Mar 4, 2025
Fox 5.0 Mustang Tech Jul 29, 2025
AeroCoupe
