Air Bag light flashing ???
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Mar 16, 2009
TrickFlowd
240
Sayre, PA
Mar 16, 2009
  • Mar 16, 2009
Just bought a car... never been wrecked and the air bag light is flashing. Could it be a sensor or something? Clean car fax, and no signs of paint work.
HISSIN50
34
129
Mar 16, 2009
  • Mar 16, 2009
Did you retrieve the code?
Courtesy of S&2B's:
Airbag code retrieval
L
LilBlueNotch
Elizabethtown PA
Mar 16, 2009
  • Mar 16, 2009
does it have an aftermarker head unit? maybe a wire loose in the column
TrickFlowd
240
Sayre, PA
Mar 16, 2009
  • Mar 16, 2009
It does have an aftermarket cd player...
I will check the code and see what I come up with.
Guero
2,148
Mar 17, 2009
  • Mar 17, 2009
Do what I did I put black tape over the air bag area inside of the cluster to were you cant see it
ID89GT
1,659
18
49
Spokane Valley, WA
Mar 17, 2009
  • Mar 17, 2009
Or you can just pull the bulb
HISSIN50
34
129
Mar 17, 2009
  • Mar 17, 2009
If you pull the bulb, you might just make the monitor beep.
I dont know what an aftermarket head unit has to do with the blinking light.
Retrieve the codes and fix the issue.
Good luck.
TrickFlowd
240
Sayre, PA
Mar 17, 2009
  • Mar 17, 2009
Good luck.
Me either. Wasn't sure what a aftermarket head unit would have anything to do with it. I'm going to check the code here soon.
TrickFlowd
240
Sayre, PA
Mar 18, 2009
  • Mar 18, 2009
(Flash - Pause - Flash - Flash)
Code 12 - Loss of battery power to air bag firing circuit...
Anyone know how to fix this issue?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 19, 2009
#10
  • Mar 19, 2009
  • #10
I had a Code 12 in my 92, it was the Air Bag Diagnostic Monitor. Not too hard to change but its a little tight in their.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Mar 19, 2009
#11
  • Mar 19, 2009
  • #11
mine does the same thing, but i just got used to it. im not really counting on my airbag on saving me anyways, i mean my cars 18 years old almost.
TrickFlowd
240
Sayre, PA
Mar 19, 2009
#12
  • Mar 19, 2009
  • #12
Is this located behind the radio and heater controls? How much is the part, and where can I find one? Thanks!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 20, 2009
#13
  • Mar 20, 2009
  • #13
Yep its the blue box behind the climate controls. You have to have one from a 92 or 93 only, I found one for about $60 from a junk yard from a car that was not hit in the front.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
For Sale 2006 Mustang GT Steering Wheel with Cruise Controls
  • lenko
  • Sep 3, 2026
  • Other Classifieds
Other Classifieds Sep 3, 2026
lenko
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
