  • 1994 - 1995 Specific Tech
Air Bag Light
  • Thread starter Thread starter Guero
  • Start date Start date Nov 26, 2005
Guero
2,148
Nov 26, 2005
  • Nov 26, 2005
I just noticed my airbag light blinks a couple of times and then turns on, it does it every time i start the car. What can i do to fix it? Or can it be something that happened while it was at the paint job like when they switched bumpers and shock observer?
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 26, 2005
  • Nov 26, 2005
Use the light to determine what code it is throwing. Count the blinks. For an example, I'll use "code 61". It would flash 6 times, pause, then flash 1 time. There is a LONG PAUSE between different codes ..... or if you only have one code ...... it will flash that one again. Let us know what code it is .... or check this page out to diagnose the problem, fix it, & clear the code .... http://www.veryuseful.com/mustang/tech/airBag/
Guero
2,148
Nov 26, 2005
  • Nov 26, 2005
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open this is my code somethings disconnected right?
Guero
2,148
Nov 26, 2005
  • Nov 26, 2005
Well i fixed there was a wire disconnected. thanks 71 mach 1 for the site.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Nov 26, 2005
  • Nov 26, 2005
70 Mach1 ... I hate everything between 1971 & the Fox. Except the Boss 351's. Your welcome ..... glad you got it fixed!
HISSIN50
34
129
Nov 26, 2005
  • Nov 26, 2005
Nicely done Justin and Guero.
For future reference, Chris (Cman) has posted nice (huge) pics of the jumper you use under the glove box, to reset the codes.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Nov 27, 2005
  • Nov 27, 2005
Oh yeah .... I forgot to mention that about clearing the codes (the how to). Good job JT. I actually had a problem a while back that threw a code for airbag diagnostic monitor or some crap. I found the monitor (behind dash) and checked everyhting out. Nothing was wrong. So I just cleared the code using Chris' method ....... and the code went away never to be seen again!
BTW ... Guero, if you still have to clear a code, it is easy. You just use a jumper wire in the connector under the glove box. Find the write-up that JT is referring to, to find the exact how-to.
Guero
2,148
Nov 27, 2005
  • Nov 27, 2005
the light stays of now, so i dont need to clear no codes. thanks alot again,
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 27, 2005
  • Nov 27, 2005
If the light stays on I like to place a nude picture of some hot chick. Hope this helps
Guero
2,148
Nov 27, 2005
#10
  • Nov 27, 2005
  • #10
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
J
Front neoprene front bumper painted color of my 71 Mach1 some hair line cracks
  • JJHstang
  • May 25, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 30, 2026
Mcmahst
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
